Question about Garden
I have a 1997 White FST-16 Lawn Tractor. The brakes are almost gone. The dealer told me that the brake pad is inside the transmission housing & inorder to change/repair it the transmission must be opened up to get at the brake arm & pad. I thought if I could find a good repair manual & could do the job myself. My problem right now is that I can't find a manual for a White FST-16. Any suggestions? Am I '' biting off more than I can chew''? Thanks for any advice.
I have a white 19 hp that I had to replace the differential. look for the brake disk on the side of the differential, there is a brake disk assembly. I think it's only two bolts and half the housing comes off ,then you can replace the brake disks and reassemble.
Posted on Dec 11, 2011
  • 69 Answers
Not sure, but here's a parts diagram...
http://www.partstree.com/parts/?lc=white_outdoor&mn=13AR616G190+FST-16+(1997)&dn=0021800004
Never heard of brakes inside a tranny housing before...
Posted on Sep 09, 2009
How do you adjust the clutch/brake on a John Deere LA105 tractor mower?
Replace the spring on the lever as it most likely stretched.
Oct 17, 2017 | John Deere Garden
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
How do you get the transmission to lock
Many have a lever at the rear that can be used to disconnect the tranny so it can be pushed or pulled .
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
Tecumseh gearbox 11.5 HP craftsman lawn tractor/brake assembly
It needs both pads . the caliper is probably rusted and that is why it appears that there is not enough rooms
May 25, 2013 | Garden
John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Sep 29, 2009 | Garden
C120 Wheel Horser Tractor
no there is no brake inside. when you push the clutch down does the belt stop turning ? If the belt does not stop that is the problem
Aug 31, 2009 | Garden
We have a 1 yr old Craftsman 24 HP lawn tractor Model #917.28870 that sounds fine, but BARELY moves forward. It does move in reverse a bit more easily. It feels like the parking brake is engaged when you...
It sounds like the brake plate is sticking on the transaxle,if you look on the right side of the transaxle a rod and spring run back from the front to a plate,under this plate are two 1/4 pins that actuate the brake pads on the disc,lubricate these pins with wd-40 and move the plate back and forth to see i this frees the problem up.
Jul 07, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have no brakes on a john deere 160 lawn tractor
You have your brake rod is not attached or brakes need adjusted,or needs new brake pads !
Apr 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
307 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
