Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
While I was vacuuming it quit working..... I have tried everying can't get it to start up again...... just silence when I push the switch
    Brigadier General:
  • 4,088 Answers
Try pushing in on the power cord at the plug end while trying to start it. If the wiring has been broken there (common failure point), the unit may come on for a moment. If it does, cut off a couple of inches of the cord, and replace the plug with a replacement plug from the hardware store.
Posted on Sep 08, 2009
When I push start, immediately vacuum stops.
That is the way vacuums work. The switch is a toggle, press it once, it starts, press it again and it stops. So what is the problem?
Apr 10, 2017 | Vacuums
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover u5140 900 doesnt start....its dead
These are known for switches going bad. The new switches are much better. They get hot and stay in either the on or off position when they go bad. Remove the top cover to reveal the back of the switch. Not difficult to change. This is your part:
http://www.vacuummedic.com/product.php?id=395
Good Luck!
Vac Dr.
Oct 07, 2012 | Hoover Tempo Widepath Upright Vacuum,...
System quit working green light on
depending on the year of your machine, assuming it is the serenity blue, it may be the circuit board on the unit itself. The manual switch "should" start the machine, but if not it will be the circuit board inside the main unit.
however....
if your unit is the green one, it may be the motor inside the unit and/or the circuit board. Hard to say. I do not think that it is the motor as the circuit breaker should have popped out if it was the motor.
Regardless of the colour of the unit, if it is 5-7 years old or less, the unit should still be under warranty. home service calls and labour to install the motor would not be covered.
Good luck.
Nov 19, 2010 | Beam Industries 2775 Serenity Plus Central...
My powerhead shuts off on its own and then i must push the switch again.
Just had this with mine and I think it is the power wires embedded in the hose from the cleaner to the powerhead. Turn the cleaner on then work your way along the hose kinking it or moving it until the power head stops. Switch the power head on again and kink the hose in the same place, if it turns off every time like mine, that is where the break is. I haven't worked out if the cable cores can be replaced or repaired yet. Hope this helps. Chris.
Aug 18, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
Electrolux ambassdor will not run after pluggen in
Greeting from GoVacuum,
On all Electrolux canister vacuum cleaners, there is a kill switch, that will not allow the machine to turn on without a bag in it. Sometimes when replacing the bag, the bag is placed in a position where the switch is not being activated.
When you open the bag housing, it should look like this;
You'll notice in the bottom right corner of the bag housing, the kill switch to the vacuum cleaner.
Try plugging the vacuum cleaner in, and while you are pressing this kill switch down, turn on the vacuum cleaner. Does the vacuum cleaner turn on/off when you push/release the kill switch? If it does, simply just get a new bag, and make sure that the new bag is covering the kill switch, and close the door of the vacuum cleaner.
If it still doesn't start, let me know and I'll try to help you diagnosis the machine differently. I'd say that 6 out of 10 times, this kill switch is the problem.
I hope this helps you. Please email me with any questions, or if this fix doesn't make your vacuum work. I really enjoy sharing my passion, and expertise in repairing vacuum cleaners.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 03, 2008 | Electrolux Vacuums
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
159 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
