Question about Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver
The time is no longer accurate, it reads 330:35 eastern time right now! I have tried resetting it but to no avail?
How do i reset the time on my samsung sph-m510
Posted on Sep 09, 2009
  • 5,603 Answers
REmove the batteries and power for a few minutes. Then reconnect. It may take it a day to re-sync with the NBS standard clock.
Posted on Sep 08, 2009
Invacare lynx4 shows full charge when I turn the key on when I turn the key off the charge goes to the yellow area either way the scooter won't move. Tried leaving key on no changes any ideas
Hi again U mentioned U left the key on,* some scooters have a shutdown circuit in the control box if u leave the key on for aprox 30 min it turns of. try removing key for a short time put it back ,& try it.we get the batteries load tested this will give U an accurate Reading on the condition of them the charge light on the scooter is not an accurate reading , load tester available on E/,,BAY APROX cost $35..... cheers
Aug 01, 2016 | Invacare Health & Beauty
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
How do I reset the clock to reflect eastern standard time in America?
On Windows, click on the clock icon on lower right and then select the proper time zone for your area and press the enter key.
Mar 08, 2015 | Lenovo 3000 Computers & Internet
It pumps good until it gets up near the 135 psi cut out, then it stalls the motor and trips the reset. This unit has 10 hrs on it, but is 2 yrs old. Tha
I would say that the 135 reading is no longer accurate and that the gage has gone bad over the years. Try a new gage and turn down the high stutoff setting 5 or 10 pounds.
Mar 04, 2011 | Ingersoll Rand Plumbing
I have a Casio Wave Captor 4757 WVQ-142E and after the change in time this fall I can't seem to set the time correctly. I am in Paris, so GMT +1, however it is 10:30 and my watch reads 3:03. I have reset...
I sympathize, it took me ages to work this out - I had the same problem having had the battery replaced in my watch which only lasted 18 months...the irony was that my previous watch was still working & set to the correct, time date etc!
The following instructions are for the Casio Wave Ceptor 4757 WVQ-142E, the official Casio instructions are available at the following:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4757
For the extra information Casio neglect to tell you in the manual, read the following:
First, the watch needs resetting. To do this you need a watchmaker's screwdriver, remove the back (4 screws - obviously, you do this at your own risk), remove the thin plastic cover to reveal the battery.
On my watch on the battery cover it says to reset the watch, get a pair of tweezers & connect the battery back to the negative (marked -) plate for about 2 seconds, thus forming a circuit.
The watch stops, the screen goes blank for about 30 seconds, replace the plastic cover , back & screws.
Wait until the watch has picked up the correct time signal, the digital part will show the correct local time, the analogue screen won't at this stage.
Set the watch to the desired time zone that you require or HS (Home Setting).
Then press button "C" (bottom left) to scroll through until "HS" is displayed on the screen, then press button B (top right) for about 5 seconds until it flashes "OO" in the screen, then press the A (top left) button down & to reset the analogue time (so all 3 hands are pointing up) to 12 O'clock, it has to be set to 12 so the watch will recalibrate itself, if it is not set to 12 O'clock, it won't work! - sadly Casio don't tell you this bit in the manual....& of course this is really obvious to us mere mortals!
Now that you have aching hands & repetitive strain injury, press the B button (top left) to exit the (watch) hand setting mode & the watch will now wind the hands by itself to the correct analogue time, (or in theory it will, it took three attempts to set my watch).
Yes, for the record Mr Casio, if you hand a watch to someone & tell them to set it to the correct time, they will set it to the current local time (assuming that it is not 12 O'clock) & as opposed to 12 O'clock by default!
This is not rocket science, if your company is able to make & market a radio controlled watch which is in theory accurate to one second in a million years because it is controlled by the Rugby atomic clock, you'd think that the instruction department could write some decent instructions!
Hopefully this solved the problem!
Nov 02, 2010 | Watches
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
Aug 10, 2010 | Timex Automatic Watch
How do I set my clock on my computer? It says that the time is 6:45PM when it is actually 9:36PM eastern stander time..
double click the clock/time in the system tray in the lower right of your computer screen, then click on the time zone tab and select the eastern standard time zone and tick off the box in the lower left of that box for the automatically adjust for daylight saving time, then select apply in the bottom then ok...now recheck your time..it should now read the correct time.
bill
Jul 16, 2010 | Dell Dimension 3100 PC Desktop
Cannon mp160 erro code E27. what to do
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-19
Jul 29, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver Logo
192 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
