Toshiba 32HL57 32'' lcd
Sound, but black screen on all inputs, incl. cable....
sounds like backlight/ inverter problem according to blogs/posts...
how do i get parts and replace myself?
  • 38 Answers
Hello. You could be right in a way, but the larger tv's have more of a complex inverter. The way you can try to fix it yourself if you know what your doing, would be to download a manual for it. Google the model number along with download schematic. try this website to see if your schematic is available for free.http://www.eserviceinfo.com/ If not, then you can call toshiba and find out where to get one. After you receive it, then go through the troubleshooting steps to trace down the problem. If it turns out that it say is a defective power supply module or video module, you can google the module number and some times you can find them used. if not, you have to go directly to toshiba. Good luck ! Ron
Posted on Sep 09, 2009
Rca tv powers up has backlight no sound or picture replaced main board and inverter
I would check the input board for correct power supply input
check the blue 15pf 6kv caps near the output from the PSU to the inverter.
Aug 31, 2014 | RCA 46 46LA45RQ LCD TV
Toshiba satellite M305 S4907 comes on but monitor is blacked out can barley see
http://www.screentekinc.com/Toshiba__Satellite__M305-series-laptops-lcd-screens.shtml
The Toshiba Satellite M305-S4907 Notebook PC, uses a single CCFL for a Backlight.
Primer before we go on;
An LCD screen cannot produce light. It needs an additional light source,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor image.
The additional light source is a Backlight.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
A screen Inverter is used on laptops that use CCFL for Backlighting.
A screen Inverter converts the power (Electricity), from the laptop, for the LCD screen, and Backlight.
Laptops that use a series of LED's for backlighting, do Not use a screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
http://www.sparepartswarehouse.com/Toshiba,Satellite,M305-S4907,PSMD8U-02R015B,Laptop,Inverters.aspx
The plastic thin frame in front of the LCD screen, is the Display Bezel. (Toshiba = LCD Bezel)
The screen Inverter is located behind the Display Bezel, and mounted at the bottom of the LCD screen.
(LCD Screen Frame, actually)
Easy to get to; easy to replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
How to test a screen Inverter? Requires a Sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Because of this; and the low cost, plus ease of replacing; most home users just opt to replace it.
Know this;
Fluorescent lamps have MERCURY inside. HIGHLY poisonous.
Now couple that with the long thin makeup of the CCFL, and how easy it is to break it.
This is why if the screen Inverter is found to NOT be the problem; I would suggest replacing the LCD screen itself; instead of trying to replace the CCFL, and cause possible Mercury poisoning.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 12, 2012 | Toshiba Satellite Computers & Internet
My toshiba 22cv100u screen is black when I have tv on, i have sound but no picture
your backlight may be out....I working on one with same problem...the transformer on the backlight inverter board went bad, its about 12 dollars on ebay....but in your case, would require some troubleshooting to determine if you have the same problem. there is an access panel on the back of the tv, under that is 4 connectors, they are high voltage out to the backlight lamps. you would need a volt meter to determine if the lamps are bad or the board
Mar 10, 2012 | Toshiba 22CV100U 22 in. LCD HDTV/DVD Combo
My toshiba laptop will boot when I power up but the screen stays black
Jeff, connect an external monitor for a diagnostic test.
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the back of the laptop,
(RGB/Monitor connector,
http://en.wikipedia.org/wiki/VGA_connector )
The external/VGA monitor can be a CRT type (Looks like a small TV), or a flat LCD screen that has a VGA cable.
Turn the external monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external monitor. If not press, and hold down on the Fn key, and tap the F5 key. (One of the Hot Key's)
If the display still does not show, hold down on the Fn key, and tap the F5 key again.
There are three display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
If graphics show on the external monitor, you have a problem in the Display Assembly, and/or the Video Cable.
If graphics do Not show on the external monitor, you have a problem with the graphics chipset on the motherboard.
(ATI Radeon 3100)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/laptop-disassembly-1.htm
Video Cable
1) Could be the connections. The connection of the video cable TO the motherboard, and the other end of the video cable TO the back of the LCD screen. (In the Display Assembly)
2) Could be damage to the video cable. Check the sheath of the cable for obvious signs of damage. If so, the thin tiny wires inside may be damaged also.
Cable should be checked for continuity of each wire in the cable. (Ohm's with a multimeter)
Video Cable condition, and tightness of connections check out, it's on to the screen Inverter.
Primer:
An LCD screen does not produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL, or a series of LED lights.
The Toshiba Satellite L455D-S5976 Notebook PC, uses 1 single CCFL for a Backlight.
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault is the Inverter.
The screen Inverter is a small rectangular circuit board, and is located behind the Display Bezel, an at the bottom of the LCD screen,
Example of screen Inverter,
http://www.battery-stores.co.uk/laptop-inverter.php/toshiba_Satellite+L455D-S5976_205_5226.htm
Link to a free Service Manual for the Toshiba Satellite L455D series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Under the main Toshiba heading go down to the subheading -
Satellite A10. (A10 is in blue)
In this 'paragraph' go down to the third line, and scroll across to -
L450D, in blue.
Click on L450D.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { L450D } it may take up to 30 seconds before the first page comes up.
Would appreciate it if you would post back in a Comment with your findings.
Regards,
joecoolvette
Jan 15, 2012 | Toshiba Satellite L455D-S5976 Notebook
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Dec 20, 2011 | Hisense TL1700 17 in. LCD Television
Screen is black with sound and hdmi inputs working
Tv turn on now,have flashes a pictures few sec.than dies have sound left only?Yes,than those 2 long one to right and one to the left boards call the LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Dec 06, 2010 | Samsung LN40A450 LCD TV
The tv turns on but all i see is a blank black screen.
Check to see that the input set for the tv is correct. If you have sound you may have the backlight out probably due to a bad inverter board. If you are unsure of the input or the cable box operation ,hook the tv directly to the cable jack for a test.
Mar 13, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Black screen no picute - sound only
It can be that the backlight inverter boards (2) have gone out, look to see if you do have 24vdc feeding the board, otherwise it can be bad power supply, look for bad caps.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Toshiba+32AV500U+
Jan 03, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
White screen no picture with sound on toshiba 26wlt66
If you do have white screen, then the problem can be in the LCD controller board, check for 5vdc on that board. If the screen is black then there are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 25, 2009 | Toshiba 26WLT66 26 in. LCD Television
47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
Dec 15, 2009 | Toshiba REGZA 47HL167 TV
Televison & Video Logo
612 people viewed this question
Top Televison & Video Experts
