Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
How to change battery on my Casio Wave ceptor
The battery is been hold by a kind of ring, don't want to pry hard, any suggestions please.
  • 2 more comments
  • RobinF Mar 09, 2008
    So how do you short the battery to A/C?
  • j_zo Feb 23, 2009
    what is this **** that pops up when I simply hover over the above "picture" link? Then if I press the link an HP ad opens. What!!?
  • harryhill Sep 06, 2010
    Just poke pin in at right angle.
    Do you mean straight down?
    harryhill2475@gmail.com--Sep 2110
  • xmBill Mar 16, 2012
    I've changed many watch batteries and this one did cause me a little problem. I tried the jewelers screwdriver and a paper clip as i didn't have a pin. That didn't pop it loose. I ended up just taking my thumb and pressing down on the clip towards the green part and the clip came right up. It didn't even require much pressure and no tools. Hope that helps.
Follow instructions. Just poke pin in at right angle.
Posted on Jun 27, 2009
  • dukeisduke Sep 20, 2010
    The answer still isn't very clear. Mine is a 3504 (WV-58A). I basically broke off the plastic retainer on mine (I heard it fly out). I went ahead and replaced the battery anyway, then held the battery cover down while I replaced the back and put the screws back in. It's still working, 10 minutes later. Oh well, it's a $28 watch from Wal-Mart. A pretty poor design if you ask me. Why not just use a screw (like the ones on the cover) to hold the battery cover down?
    Okay, now after thinking about it, I think I understand how it works. There's a notch in the black plasttic retainter, and you want to put the pin in that notch, then move the pin so that you push out from that notch, The battery goes down in a square "U" shape, under the black retainer. The object is to push the bottom of the "U" forward, out from under the black retainer, so that it disengages. Then when you replace the battery, puching the cover down causes it to snap back under the retainer.
As far as removing the clip that covers the battery on the Waveceptor 2735, I found that even my smallest screwdriver was too big but a pin from my wife's sewing machine worked well. I poked it down on the right side of the clip in the small hole then pulled gently to the left using the pin as a lever until the battery popped up. I touched the battery and the little circle with a (-) on it for two seconds and it worked well.
Posted on Mar 11, 2008
  • 29 Answers
The strap that goes across the battery is hooked down the side of the battery. You need to get a small thin standard screwdriver ( the kind you use for tiny screws) and go down the side of the battery, insert screwdriver where strap is hook, pull away from battery and it should unhook. This watch the battery has to be short circuited by taking tweezers and touching the AC & the battery for 2 secs hope this is helpful. galrygal
Posted on Mar 01, 2008
  • Lloyd Brown Dec 30, 2013
    What is the AC?
Worked well!
I guess a picture may help the less experienced?
Posted on Aug 31, 2008
  • hackbarthg1 Aug 08, 2010
    Picture really helped!!!! The pin worked best. Popped right out when hit the whole in the right place.
  • 3 Answers
The bracket has a square clip hanging downwards. You want to stick the pin in close to and angling towards the battery so that you get the pin inside the clip, then gently pry so that the bottom of the pin pulls the clip away from the battery.
To reiterate, the bracket is all one piece of metal with a 90 degree clip hanging down the side. It's that 90 degree clip that you want to pry the bottom outwards.
Posted on Nov 13, 2011
I've got the same question, Fredo. Do you have a solution yet?
Roger
Posted on Jan 31, 2008
  • 72 Answers
Another thank you - to RonA, this time. The clip does indeed come out, so does the battery. For $4 I have a working watch for another 10 years.
Posted on Nov 02, 2015
I was trying to lift up the wrong side of the clip ... It actually does "just pop up" when you stick a pin or screwdriver down the correct side. If it seems to hard ... try the other side!
Posted on Jun 12, 2013
SOURCE:
I need instructions on setting the time on my Wave Ceptor 4756 142A. Recently replaced batteries and lost manual.
browse through my tips and you will find link for all Casio watch manual downloads.
Sep 28, 2010 | Casio Watches
How to replace battery in a Casio watch
You dont change the batteries on a Wave Ceptor. These watches have a battery cell that is charged by solar power. To learn more about your watch and download a manual, etc go to:
http://www.casio.com/support/
Best regards.
Aug 23, 2010 | Casio WVQ600DCA Wave Ceptor Watch
How to switch wave ceptor back on after fitiing new battery
Find it here:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Mar 29, 2009 | Casio Watches
New battery can not reset watch CASIO #2735 Atomic wave ceptor
Did you try this?:
Rate, please.
Mar 28, 2009 | Casio Watches
I don t know how to set the time on my casio ceptor watch
Follow this link:
Enter required details and download instructions.
Rate me, please.
Mar 14, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio wave ceptor 3747
Use this link to read Direct Casio manual:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3747.pdf
I suggest you may need to wait till the first signal is received by watch.
If all this doesn't work, then check the battery condition- it may be underpowered and need replacement. Eve if your watch is brand new, the battery may be few years old.
Do not forget to rate, please.
Jan 26, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
3747 Replacement Watch Band
Use this link to get in touch with Casio:
http://www.casio.com/home/
Choose relevant application under the SUPPORT. Here you can find Technical Support, Casio Parts etc.
Choose your nearest region and ask to supply new watch band.
Jan 13, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
32,848 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
