Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
50 inch sony wega will not turn on
I just got this tv from a guy that didnt want it.. When i turn it on, the power/standby button blinks 80 times and then the tv sounds like it turns off, and the lamp light starts blinking red. There is no picture at any time, like theres no power.. Can you tell me how to fix the problem?The model number is KDF-E50A10
  • 68 Answers
Probably need to replace the lamp.
Posted on Sep 10, 2009
Sony 3lcd wega engine tv screen turns black, power/standby button blinks 45 times, then screen goes back on. This repeats over and over again. Do you know what's wrong with my tv? Thanks.
First check your tv if it has standby power. if it has standby power please do count the number of blinks of red led. (it is on a sequence) so that we can walk through the steps and procedure to get rid of the trouble. if theres no stanby power, its probably the power supply. please do check busted fuse and replace with same ratings.
Apr 16, 2013 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony HD-TV KDF-50E2000 blinks 15 times pwr button then turns on. After about 2 hrs turns itself off and blinks 40 times then turns itself back on. shorter and shorter on time thoughout the day. No led...
Symptom shows Lamp is getting weak and its time for new Lamp in TV.
Lamp replacement procedure is written in user manual.
Please buy Sony original lamp for TV safety.
Thanks.
Jul 03, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Cut tv off now it won't come back on its a sony hdtv wega
ok. the error codes for your model only go up to 10 blinks. Carefully count the blinks as there should be a slight pause then blink again.
Jun 22, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
562 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
