Question about Epson Stylus Photo R800 InkJet Printer
Black ink smudges on paper as if the ink is building up on something then getting shmeared onto the paper as it goes through. The smudges have no relation to the picture that is being printed It is the worst along the margins of the page.
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Ink smudge on right side of paper
Chances are high that the process of clearing the jam has resulted in ink being released from the cleaning/resting pad area based over on the right hand side (where the printhead sits when not in use).
This waste ink has probable come into contact with the rollers and other parts over on the right edge of the paper.
You'll probably see this ink slowly fade out and disappear over time. If it doesn't however there's something effectively feeding things so check the resting pad for a loose tube, overflow, puddles, etc...
If there's anything like that, report back (preferably with images).
Jul 21, 2013 | Epson Office Equipment & Supplies
The ink smudges on the paper.
The "fuser" is the part of the laser-printer that melts the dry toner-ink onto the paper.
If the fuser is not getting hot enough, or is not working at all, then the toner-ink will smudge.
Take the printer to a qualified technician for servicing.
Apr 20, 2011 | Brother HL 5250DN Laser Printer
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Black smudge on side of paper when printing quanities
Hey, Pleas check Black imagine unit,if needed change it.
Jan 07, 2009 | Konica Minolta Magicolor 5450 Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
Ink smudge on corner of brochure paper
Ink getting onto the paper when it should not is usually a sign the waste ink tank need cleaning out. Go to www, fixyourownprinter,com for a deeper insight. Also the Canons own Tech Support team
May 31, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Laser Printer
When the paper is fresh out of the printer, does the ink that looks okay smudge if you rub it with your finger? If so, it means the fuser is going bad. Otherwise, it's probably a bad toner cartridge that's leaking toner onto the paper.
Jun 12, 2006 | HP LaserJet 2100 Printer
Epson Stylus Photo R800 InkJet Printer Logo
365 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
