Question about Sharp EL-1801P Calculator
How do I change the paper? - Sharp EL-1801P Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Follow the illustrated instructions on the first page of the manual at http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1801P.pdf
Posted on Jun 10, 2013
I want to change papar orientation from landscape to portrait. I changed it in paper tray but paper orientation in printing does not changed. plz guide.
Dude, changing paper orientation on paper tray is just one step, while you must change paper setting on printer driver too. In some machines, you should change paper switch position too :)
Sep 30, 2013 | Toshiba EStudio 223 Copiers
Encoder strip
will u clean paper feeder assembly, paper sensor ? will not ? clean paper sensor its a bottom of paper fee. assy
try other things.. change u r paper feeder assy.
change u r head carriage assy. cable. it has 20 pin cable.
change u r head carriage assy...
Sep 17, 2013 | HP Officejet 5610 All-In-One InkJet...
We changed the paper type in tray 3 to high gloss and need to change it back to regular paper but we can't remember how.
Open and close the paper tray 3.The tray information screen will be displayed.Select CHANGE SETTING on the touch screen.You should now be able to change your setting.
Oct 20, 2011 | Xerox WorkCentre 7328 Multifunction laser...
The copier is flashing at the "error" light and the screen reads "change reccomended size, common settings" I don't know how to change it
To change paper size on Drawer 1, Go to Additional Functions > Common Settings > Reg Paper Size > Drawer 1 > Paper Size > (Select the correct paper size) > Press Ok
To change paper size on Stack By-Pass, Go to Additional Functions > Common Settings > By-Pass Std Set > (Select ON) > Paper Size > (Select correct paper size) > Press Ok
Oct 24, 2010 | Canon imageRUNNER 1023iF Black and White...
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
My photocopier has 3 drawers - First is universal and 2 & 3 are both set at letter. I would like to set drawer 3 to legal. how do I get the copier to recognize the change?
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Imagerunner 1023if How do I change paper size on printer
you need to change the paper size on the copier or the paper tray dial.you can also select a paper tray from the printer menu..Alt set the printer properties to a paper tray with legal paper and it should overide the setting
Aug 10, 2009 | Canon imageRUNNER 1023iF Black and White...
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Hp laserjet - 4200
Change your Paper type in the Paper Handling Menu. Is paper fed from tray 2 or tray 1? Either setting, the paper type can be changed using the control panel. Press the green button to enter the menus, then using the "down" arrow button, press until you notice the "Paper Handling Menu". You can change the setting from Rough Paper to Plain. I hope this helps.
Nov 04, 2008 | Konica Minolta magicolor 2400 Laser...
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Sharp EL-1801P Calculator Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
