Question about Emerson DTE315 TV
Code for model DTE314 CHANNEL BLOCK
EMERSON
  • libby2008 May 19, 2008
    NEED RESET CODE FOR V CHIP
    CAN NOT FIND ANYTHING ONLINE TO HELP
2 Suggested Answers
SOURCE: Channel block
#1 power off #2 hold the menu butin down and tren power on for 40 sen. #3 tren power off #4 do it 2times #5 tren power no all ok
it worked for me good luck
Posted on Sep 05, 2008
Emerson DTE314 need part # for IC 401
The part number is always printed on the front or top of the IC.
If that helps.
Mar 10, 2011 | Emerson DTE315 TV
I have an emerson ewf2006 tv i have no remote but i do have a philips universal remote model cl034. i cant seem to find a code to make it work. does that remote even work for that tv? or do i need to...
Hello
Your Philips CL 034 model remote control should work with almost all models of Emerson TV. Codes to check with are
0002 0502 0006 0115
0506 0706 0520 0906 0316
0505 0614 0324 0924 0626
0826 0027 0327 0128 0228
0632 0134 0247 0605 0705 0805
0703 0903 0004 0519 0106 0104
0304 0604 0804 0005 0105 0305
Be patient and check with these codes one by one, till you find the code for your Emerson model.
NB: Switch OFF and switch ON your TV set, with its front panel power control switch, before trying an other code.
Proceedings
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
OK.
Feb 28, 2011 | Emerson EWF2006 TV
Emerson model ewf2004 universal remote code
Hello
Three digit universal remote code for Emerson are:-
002 003 004 005 104 105 106 115 204 205 206 213 304 305 316 319
405 502 505 506 519 604 605 705 804 805 903 904 905 906
009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit universal remote code for Emerson are:-
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 28, 2010 | Emerson EWF2004 20" TV
Turns on the shuts off
I had the same exact problem!!!! If you unplug it, then plug it back in after a couple of days. You will hear a frying sound then a loud clap!!!! Solution: Replace it with a LCD.... Not worth getting fixed!!!
May 26, 2009 | Emerson DTE315 TV
Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
Feb 11, 2009 | Emerson EWF2703 27" TV
CODE FOR A REMOTE CONTROL
I am not sure of the model remote but, on the newer TW remotes you would press tv then press and hold set up until the tv light blinks twice. then enter 991 on the number pad and then press power once. then press the channel up button until the tv turns off. as soon as it turns off - press the power button and if it turns on then you have the right code. If it doesn't turn on then press channel down until it turns on. either way, when the tv turns on then press set up again to lock that code in. Hope that helps.
Feb 10, 2009 | Emerson Televison & Video
Channel block
Aug 18, 2008 | Emerson DTE315 TV
DTE314
TECHNICAL SERVICE DATE
Mar 05, 2008 | Emerson DTE315 TV
Codes
I have the same problem with the Cox Cable remote attempting to make it recognize my Emerson model LC320EM8 HD TV. The booklet with the remote shows 20+ codes for Emerson TVs and I tried them all, I then tried the channel up/down search, to no avail. Is there a code for this TV, or do I have to buy another Radio Shack universal remote like I had to do with my other TV home theater system?
Dec 04, 2007 | Televison & Video
Input select function... without a remote?
Whew! Found the NE116UD replacement for the EWF2704 Emerson TV (there are other models on the list as well), it can be ordered here for 24.95:
http://www.emerson.newremotecontrol.com/catalog_item.php?catnum=NE116UD
Hope that helps. This problem is certainly very irritating. I have never heard of a remote for 24.95, nice job Emerson -- never again!
Nov 12, 2007 | Emerson EWF2704 TV
Emerson DTE315 TV Logo
208 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
