Question about Acer TravelMate 2300 Notebook
Wireless adapter I have a wireless network service with Sky tv useing a netgear router.I cannot connect to wireless cause i do not know how to configure my built in wireless adapter to Sky.I have an Acer TravelMate 2700 laptop. Can you help Regards Ken
  • 56 Answers
This link will help your problem....all steps and procedure will have this link of site..............
http://kbserver.netgear.com/kb_web_files/N101145.asp
Posted on Dec 22, 2007
Netgear wirless - installed on toshiba satellite a45 - S151 will not connect to internet router = comcast - linksys also causes conflict with connection of other wireless computer
Presumably, you have configured your wireless router:
* SSID (your "network name")
* encryption-level ('WPA' or higher security)
* password for your network
With that information, any wireless device (iPod Touch, iPhone, NetGear wireless adapter) should be able to connect to your wireless router.
Exactly what error-message are you getting?
Feb 21, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wireless adapter wg111 push n connect does it work with sky router
No this it not work with this adapter. You need to manually connect to the wireless network using the adapter or windows utility. Let me know if you need further assistance.
Oct 11, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Netgear Wireless - G USB 2.0 Adapter
Hello, Joe.
Assuming Sky doesn't prevent access to non-sky internet services (if they did something crazy like that, it is most likely a Sky specific firmware that was put on the router, which would mean you need to put the Netgear firmware back on), I would say you have something set up wrong.
Can you get to the internet through a wired connection? If so, wireless is probably configured wrong. If you can log into the router, that would give you an easy way to find out how thw wireless is set up. goto your web browser (on a wired connection to the router) and type "192.168.1.1" or "192.168.0.1" When prompted, type in your username and password (probably, "admin" and "sky" or "admin" and "admin").
If you can't log into the router then you'll have to try and figure out the connection through trial and error. When you were with Sky and the tech installed your router, did he/she give you an encryption key to use when you connected? If so, I would try "shared WEP" first (providing the WEP key given to you). If that doesn't work, try WPA-PSK.
Hope this helps,
Bill
Sep 03, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have Sky Broadband withe netgear router. Bought a netgear wireless adapter to use with my Advent PC. Installed everything. Good connection, but won't connect to internet. Keeps flicking from connected to...
HI,
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as sky (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
scan for the wireless network on the computer with the adapter and connect to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Aug 03, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Netgear WG111 doesn't see D-Link DIR-655 wireless network
Hi Joe,
I would suggest you to change the wireless channel on the Dlink and use the channel on which WG111 will scan and connect to your network. Also, plese make sure to use the security encryption on the DLINK to WEP or WPA only. Using higher security like WPA2 will cause issues with this adapter.
Regards
Anand
Jun 21, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless connection
i can't connect wireless int
Feb 01, 2009 | NetGear DG834G Router
Wireless network card & sky broadband wireless router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Oct 20, 2008 | NetGear RangeMax NEXT WN511T...
Netgear wg111t
There are several problems reported that may cause disconnection. First is the hiding of the SSID (wireless1.gif network1.gif name) and enabling WEP or WPA encryption. The recommended solution for that is to unhide the SSID in the router configuration.
Second is that there are more and more wireless devices and occasionally interference occurs on a single channel (even from non computer devices like wireless phones1.gif. As routers are often set to channel 6 you may be competing for radio communications1.gif with your neighbors. The recommendation is to switch the router to either channel 1 or 11. If your first choice does not work try the other.
Also watch out for wireless phones base stations too close to routers.
Dec 20, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
158 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
