Question about Yamaha HTR-6030 Receiver
I dont know how to hook vidio from reciever to tv monito, I have sound from dvd and vcr but no video
Downloaded manual and bought componet cables for hook up
Posted on Sep 09, 2009
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
I hooked my player up to my RCA tv, but it will not show a picture when I record a TV program. I have cable. What am I doing Wrong
You might have an INPUT going to an INPUT, or vice versa. Always make sure that an INPUT goes to an OUTPUT and an OUTPUT goes to an INPUT. If this is not the problem, then you have a faulty cable somewhere, test it and if faulty, replace it. Good luck to you!
Nov 27, 2009 | Philips Magnavox DVD/VCR Dual Player
My akai receiver to my vcr
hi my name is mark, if you have cables. first unplug the power cords to the vcr and the receiver. on the back of the vcr there will an input and an output audio and video connectors. if your vcr does not have them you will need a new vcr that does. if you just want sound, find the Output connectors. there will two. they will be idenified as Audio OUT. plug one end of the red plug into the one labeled Audio R OUT, then the white in the one labeled Audio L OUT. if you are connecting the video up connect the yellow plug to the connector labeled Video OUT. the other ends connect to the receiver, on the back of the reciever find connectors labeled vcr or dvd AUDIO IN. then connect the red plug to the connector labeled R IN and the white plug to the connector labeled L IN.if you are just hooking up sound you done. to hook up video find vcr dvd Video IN and connect the yellow plug to the Video IN. on reciever. if you want the reciever to switch the TV you also need to run a yellow video cable from Video Out from receiver to Video IN on back of TV. when finished plug in vcr and receiver. select dvd or vcr on receiver to listen ot vcr on the receiver i dont know what model you have or it features i hope this helps thanks for your question.
Mar 17, 2009 | Akai 42 in. LCD TV
No sound when the tv is on and the mute is turned off
I still am unclear as to your hook up but lets try this, if you have your DVD/VCR plugged into the TV audio and video and a audio cord from the tv monitor out to an input on the reciever, this way you should hear the sound at the tv and reciever.
However if you have your DVD/VCR plugged into the reciever first audio and video connections made at the reciever you should just have a video cord fromthe monitor out of the reciever to the tv and your audio will come from the reciever
Feb 25, 2009 | Panasonic PT-52DL10 52" Rear Projection...
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
Pioneer vsx-d850s Home theater help needed
well i dont know how much they differ but i have a vsx-517 reciever(pioneer) all i do is run the one video out to my tv and run everthing else through my reciever.my configuration is i have the tv/sat input hooked up to my dvd which has an video out and then my sat was hooked to dvr/vcr input hope this helps alo there is loudness setting and speaker configuratino as well i have my effect turned as far as they will go so i suppose it punches out fairly decednt volume at -60 through 35 any further and i sometimes overload my system lol anyway hope this helps if you need and idea on what it look like ill take a pic ans send it to you-z
Feb 18, 2009 | Audio Players & Recorders
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Very low sound on TV and DVD no tuner
audio out from your tv to your reciever gives low output? how do you have everything hooked up i have vcr to tv dvd to vcr audio to my reciever and vcr tv thru piggy back plugs therefore i can only have tv audio or reciever or both
Dec 03, 2008 | Denon AVR-2800 Receiver
CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
noavatar_s.png jdrrwoods
Rank:wizard_s.gif Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca1.gif cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
Yamaha HTR-6030 Receiver Logo
105 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
