Question about Acer TravelMate 4001LCi Notebook
My Acer 4001LCi Laptop Won't Charge and Overheats!!!
The problem has been getting worse and worse....I can plug in the power supply and sometimes it charges---if I jimmy in a pen or something to keep the cord angled in a way where it will charge. I have tried multiple chargers...that's not the problem.
My computer service guy said I need to replace the whole computer and can't just swap out the power supply? Hard to believe you can't fix that...the computer runs great---I just can't get any juice to it some days and it's a pain if I can because it goes in and out all the time.
Also, it does get very hot and the connection from the power cable can burn you when you pull it out.
HELP PLEASE!!!
    President:
  • 2,600 Answers
The charger is getting hot because the DC jack is probably failing due to cold solder points or the unit is just worn out. When the charger tip has to be "angled" and jimmied with a pen, It usually means that the little tension band that holds the jack in place has been worn out, compressed into the slot and has no rebound. You see the tension band acts like a small spring and holds tension against the plug. Over time it just gets worn out and we jamb things into it trying to get a better connection. The jack has to be replaced. It is either soldered directly to the main board and needs pro tech to do the resolder...sometimes these jacks have up to 8 solder points. The jack might be attached to the mainboard via a satellite card or cable...in which the repair can be done at home with guidance and tools. If you wish I am giving you a link below for the service manual to that series laptop. Just copy and paste into your internet browsers address bar and make sure to make a copy for yourself, it is in PDF format. Good luck
http://tim.id.au/laptops/acer/travelmate%202300%204000%204500.pdf
Posted on Sep 08, 2009
    Scholar:
  • 150 Answers
This seems to be a common problem with laptops is for the DC power jack solder connection to break. The initial symptoms are what you describe- having to manipulate the cord to make a an electrical connection. You may be able to see the jack move- it is not a part of the case- it is either soldered to the mobo or a seperate power board, possibly by wires soldered to the mobo.
Another possibility is the cord itself-four cords break internally with very little damage to the exterior- the breaks have always been right at the plug that goes into the laptop. A new plug can be bought for $ 2.00 US. DC power jacks seem to run around $ 6.00-$15.00. If you can remove the mobo youself, you can probably have the jack soldered on by a TV repair shop.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Testimonial: "Thanks for the advice. Much appreciated."
My Acer Aspire won't recognize the battery charger. I plug it in and nothing happens. After I unplug and re-plug it back in several times, sometimes my computer will recognize it and will start to...
Try wiggling the plug around a bit to see if you can get contact. You could also try borrowing a power supply if you know someone with the same machine to isolate the problem.
Oct 16, 2013 | Lifetime Acer Aspire 4810TZ-4011...
Acer aspire 5517 powers up sometimes and not others. Randomly shuts down.
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 27, 2012 | Acer Aspire 5517 Laptop
Laptop lost battery back-up suddenly.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 06, 2012 | Acer Aspire 5810T-8060 Notebook
Ive recently started to use my acer aspire one laptop and it won't charge and the charge light keeps blinking and once it hits the windows screen it turns off
Take it to a best buy or staples, ask them to hook the laptop up to a universal power supply to see if that is your problem.
if so... then you can buy a replacement power supply while you are there
Jul 28, 2012 | Acer Aspire One PC Notebook
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
Looking for driver for acer travelmate 4001lci
http://www.user-guides.co.uk/download/acer/acertravel/Acer-Travel-Mate-4001lci-Driver.html Try this web site they have drivers. But it's not free, they charge for the driver. You can find more online for free if you trype in "TravelMate 4001LCi PC Notebook Free Driver" in your tool bar. Good Luck
Apr 06, 2011 | Acer TravelMate 4001LCi Notebook
Bluetooth do not work in my laptop acer travelmate 4001lci
Here is the Acer Support & Downloads Webpage for your model:
http://support.acer.com/us/en/product_support.aspx?tab=1
Just choose your Operating System from the dropdown menu and choose Bluetooth Updates.. BUT I RECOMMEND that you Download/Install ALL UPDATES FOR YOUR SYSTEM as well.. OK? :) PLEASE DO ME A FAVOR AND DON'T FORGET TO TATE MY SOLUTION... OK? THANK YOU
Sep 22, 2010 | Acer TravelMate 4001LCi Notebook
Acer travelmate 4001lci pc notebook does not switch on power leed is oky
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Aug 21, 2010 | Acer TravelMate 4001LCi Notebook
My laptop wont turn on or charge
Let's rule out the charger.
Find a multi-meter and check the voltage. It should be listed on the power supply what the output is. For instance, I have Dell that outputs 19.5v.
You can find a multi-meter at Radio Shack, Wal-Mart, etc. Just plug the red lead into the center of the end of the cable and the black one onto the metal 'barrel' surrounding the power supply 'jack'.
Your multi-meter should be set to 200v DC.
If your power supply is outputting near the output it should, your power supply is probably good and it is going to boil down to a bad DC input on the mainboard of the laptop.
Mar 22, 2008 | Acer TravelMate 4150LCi Notebook
Acer TravelMate 4001LCi Notebook Logo
215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
