Question about Ovens
Door of the stove do not close completlely and door is not held but opens all the way almost to the floor
  • Ovens Master
  • 3,463 Answers
Sounds like you need to replace both the oven door hinges.
Please rate my solution.
Thanks.
Posted on Sep 08, 2009
Stoves 900ef oven.How can I remove the door.
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
May 30, 2018 | Stoves Ovens
I have a frigidaire self cleaning oven and range top. while i was baking the temp just suddenly went off and the door was locked. tried pushin lots of buttons, nothing happened. so i unplugged it for a...
Hi, try opening the door and looking for a little black switch on the right or left side, that the door actuates this is the door switch, while the stove is plugged in, hold this switch in and see if the lock moves.
Sean
Mar 26, 2011 | Frigidaire Ovens
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Dhow do i remove stoves efa600H oven door hinges?
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
REPLACING AN OVEN DOOR
HI thanks for the question. the locking clips were not locked, when you pulled out the oven door . lay stove door on the floor. take one hinge push towards the floor. lock small clip to the hinge ,do both. now re-install door. pull door towards you . unlock the locking clips. both. now close the door.thanks the appliance doc. please rate my answer thanks
Oct 08, 2008 | Ovens
My stove
Usually when an oven door will not close properly, the door hinges will need replacing
Jun 12, 2008 | Stoves Ovens
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
60 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
