Question about Philips Televison & Video
Just got an ''old school'' Philips tv and it gets good reception on some channels but others there is only a blue screen????
    President:
  • 1,124 Answers
Go to the menu and run a channel search.. It will go through all the channels and add the ones that have a reception and delete the ones that dont..
Have a nice day..
Posted on Sep 08, 2009
After AIR setting and AUTO SCAN, I cannot even receive local channels 4-5 miles away. What is the problem? See below for details.
There may be a problem with the antenna connection. Channels are not being sensed during the scanning process
Dec 12, 2016 | Olevia Televison & Video
Philips tv digital disappeared
There may be a firmware upgrade needed here--ask Philips what is available for this model.
Jun 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
Some channel no sound
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
Jun 18, 2010 | Sanyo Televison & Video
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
Nov 02, 2008 | Televison & Video
Digital tv reception
Any developments with the snowy Channel 3?
Good luck and thank you for using FixYa.
Oct 24, 2008 | Televison & Video
I have a plasma TV MAGNAVOX PHILIPS model-42MF7010/17
video processing is done on small signal board. If there is no on screen display ssb would the board to replace as micro processor generates the menu
Jul 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
No UHF channels
Sorry, looking up the Phillips PTV100, it does not support over the air broadcasting. Supports, cable and satellite reception.
The reason you are picking up The VHF channels (2-13) is they match cable channel frequencies up to this point. The UHF frequencies are not the same as the cable frequencies, even though the channel numbers seem the same.
Some other models or brands of TIVO may have this ability.
Feb 12, 2008 | Philips PTV100
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Snowy picture, no reception?
Hi, Your question "Do bigger TV's need an aerial booster or something?" - No, normally it should work straight out. Boosters are used for fringe location not bigger TV. Pls a questions and some ideas: 1. "TV worked fine the night before" was it hooked up to Cable or aerial? 2. If cable, it is necessary that you change the settings of the TV from cable to STD or Air or something like that. Normally this can be done via the remote, menu, setting, set-up; 3. If aerial, you would probably need the assistance of a qualified service personnel. Apparently something got loose inside the Philips TV, not a big problem because you can still receive (BBC 1) but not the other channels, possibly a loose wiring, a disconnected connector. 4. If you feel comfortable working on it yourself, unplug the tv and the aerial, open the back and poke around. Trace from the aerial jack, the lead wires used, the connector to the main circuitry. Wiggle the wires a bit for any loose connection. 5. If #4 is not to your liking or if you do not find anything or no significant improvement after closing it up and running it again, guess you're back to #3. Hope this gives you some idea. Lots of luck and kind regards from the Philippines.
Jul 31, 2007 | Philips 32PT9005D TV
Televison & Video Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
