Question about Refrigerators
I want to change the door hinge of a 2.5 cu ft Chefmate refrkgerator from hinged right to hinged left but can't find manuals that might show how. Any one have information on this or know where I can find it?? Thanks! RL
  • 864 Answers
If the doors can be reversed there should be mounting holes at the top and bottom of the doors opposite where the hinges are now. (They may be closed with plastic plugs that can be pried out.) Check also how the existing handles are mounted. There should be holes that correspond to having the handles on the opposite side. (Sometimes they are disguised by a manufacturer's nameplate over them.) If there are such holes then start at the top hinge of the door. Pry the (plastic) cover off if there is one. Remove the bolts/screws and remove the hinge support. There is a post on it that fits into the hole at the top of the door. Remove the door by lifting it up off the bottom hinge post. Keep track of any washers, etc. that may be there. Unscrew the bottom hinge support. Remove (and save) any plastic plugs and install the hinge supports and doors in reverse order (bottom to top) on the other side. If there are separate door stops on the bottoms of the doors near the hinges that keep the doors from swinging all the way open, make sure you move them also to the other side. Relocate the handles. Put the plastic plugs, nameplate, etc. in the old holes.
Posted on Sep 08, 2009
Do i have to purchase new door hinges to change the swing of the doors or will exiting hinges work to make the change???
never saw duel swing hinges . righties swing right lefties swing left , so I would say YES you need to buy the other ones
Jul 27, 2015 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
How to replace door hinge
Hello there.
Well no specifics but all about the hinges are as I explain below.
All Samsung Support info about your fridge is here.
http://www.samsung.com/us/support/owners/product/RF268ABBP/XAA
So if you want Service or a dealer near to you, this is the place.
Page 9 of the user guide WITH installation manual shows how to get the hinge off.download from here
http://www.samsung.com/us/support/owners/product/RF268ABBP/XAA#
Sep 23, 2014 | Samsung RF268ABBP 25.5 Cu. Ft. French Door...
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
I just got a used GE Profile Refridge and would like to change the door from left opening to right side opening. How would I do that?
Hi. Look carefully at the door and check to see that there are buttons on the side of the door opposite of the hinge. Those buttons conceal the alternate set of screw holes for the hinges. If there are no predrilled holes on the other side of the door then it is not reversible.
That said, If you do locate those buttons, unscrew the hinges from the door, have a helper there as the door will be heavy. Once the door is off, remove the hinges, then move them to the opposite side and reattach the door to the fridge. Put those buttons in the new open holes. J.
Jul 30, 2010 | GE Profile Stainless Bottom-Freezer...
Our French doors aren't shutting right. You have to close the left one first, and then the right one. Even if you don't need to open the right one. It didn't used to do this.
It appears that your door hinges are loose. Open each door, take a close look at hinges at the top and bottom. You may be able to see an outline of where the hinge was and needs to be. Raise / Lower Door by hand until hinge is back in place, and tighten with a screwdriver. Pretty common.
Jun 11, 2010 | Samsung RFG237AABP (226 cu ft) Bottom...
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Refrigerator door has stopped closing automatically
You may have a worn door bearing.  Have a look.  Both sides have the same hinge assembly for comparison.  Also possible that the hinges have come loose.
Clean out the hinge by spraying on a little WD 40 first...it may fix everything.
Nov 21, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE refrigerator door problem (model TBX25PAYARWW)
Is sounds like you will have a broken or worn out or bent hinge. It may be a combination of the 3.
Dec 26, 2007 | GE Americana 15.6 Cu. Ft. Top-Freezer...
Refrigerators Logo
272 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
