Question about Maytag 24 in. DWU7402 Built-in Dishwasher
I have a leak when the dishwasher is running.
Maytag DWU740GABE
Dishwasher is probably 5-10 years old. It was in the house when I bought it in 2007. Has worked fine until recently. Its used only once or twice a week. Recently noticed some leaking at the bottom right of the unit when running. Not sure where to start for a fix.
  • Wayne Holden May 11, 2010
    Pull the kick panel off and look for a drip, both running and not. Could just be a loose line or a cracked hose.
  • 5,911 Answers
This is commonly caused by a worn door seal. This is a simple repair that requires no tools and can easily be accomplished in a matter of minutes. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. The only other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel (part number 99003678) at a cost of about $115.
2. Replace the door seal (part number 902894) at a cost of about $40.
I think I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps: 1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way. 2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results. 3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers. 4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side. 5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary. This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 08, 2009
I have a mdb7100aww in a house I bought seven years ago; the dishwasher is acting like it does not have power. Is there a reset button near the bottom front? Jerry @ hjerster@yahoo.com
could be like a switch on the wall next to the disposal switch start their then door switch then check breaker wires at dishwasher could be burnt they do leak on ocasion on the wires good luck
Aug 21, 2010 | Maytag Dishwashers
Purchasing this Whirlpool dishwasher
probably a new one. lifespan is 10 years average
Apr 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Our Maytag dishwasher model MDB4000 leaks from the door, but not every use. The leak started just on the left corner, but now sometimes leaks from the middle. The diswasher is 12 years old.
Usually this is caused by a bad door seal.
It can easily be removed and replaced.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Maytag MDB6000 Dishwasher
The dishwasher is probably 12-15 years old. It
Adjust the door lock. Check the door switch wires. Replace the door switch mechanism. In this order.
Oct 06, 2009 | Maytag Dishwashers
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Maytag Dishwasher 2 years old leaking
open the door of the dishwasher and check the seal. It may have just gotten worked out of place or it could be deteriorated enough that you will need to replace it.
Dec 31, 2008 | Dishwashers
Leak
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Jun 16, 2008 | Danby 22 in. DDW396 Free-standing...
Leaking door (Running Water)
being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
Apr 15, 2007 | GE 24 in. GSD4630Z Built-in Dishwasher
Dishwashers Logo
331 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
