Question about Bose 3 2 1 GSX System
Our Bose 321 Entertainment System is only playing DVDs in black and white - no color at all.
    Scholar:
  • 76 Answers
Be sure that in the setup menu, you are selected for the correct output format (either component which is BLUE/RED/GREEN + audio or composit which is just YELLOW + audio. If that is correct, I would suggest a call to the BOSE technical support center.
Posted on Sep 13, 2009
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
Bose 321 dvd and remote
hello.
Clean out the battery connection inside the battery case. Incase this work disassemble your remote and find any fault connection in it. or let the repair man do it.
If the remote work change the setting press PBC mode this will change the color. or refer to the manual for changing view setting.
melnavz
Mar 31, 2008 | Bose 3 2 1 GSX System
Dvd playing in black and white
problem is most likly in tv menu settings. display or picture and chang to color
Apr 25, 2010 | Bose 3·2·1 II System
My bose 321 plays DVD's but color is all blue? Any idea?
I just had this same problem. My problem was that two of the composite cables were reversed, the red and blue. So, although everything was plugged in, when I unplugged the cables, I discovered the error. (A man who installed a new entertainment system mixed them up).
Apr 06, 2010 | Audio Players & Recorders
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Bose 321 display is only Black and White..all movies too
Could just be the dvds? Or not...
Replace the laser that reads the discs!
Jul 07, 2009 | Bose 3 2 1 GSX System
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
My Bose 321 system wont play CDs but it plays DVDs
lasers need changing expensive £200 or more
Dec 17, 2008 | Bose (321GS) System
Format unsupported
Format unsupported simply means the unit can not read the disc. The problem is either the disc or the player.
Contact Bose technical support if you are sure the discs are good. 800-367-4008
Jul 31, 2008 | Bose 3 2 1 GSX System
Can only get black and white images when playing DVD's
Check your settings - video format. It should be NTSC for USA standard. If it is set to European (PAL) it will be in black & white. Hope this helps.
Jul 27, 2007 | Bose 3 2 1 Series I DVD Home Entertainment...
Bose 3 2 1 GSX System Logo
381 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
