Question about LaserJet 3052 All-In-One Printer
The display on the printer reads.....
"52 scanner error turn off the turn on."
I turned the device off..waited 10 secs then turned back on, only to be greeted with the same message after the device finishes initializing. Is this a "You need service" message? The model is a HP Scanjet 3052
  • gerand177 May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
    8
My hp2840 scanner not working display message : scanner error 3 turn off and on please advice
Scanner Error
The device has experienced an internal hardware error.
  • Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.If the error persists, replace the scanning assembly.
Jul 09, 2011 | HP LaserJet 2840 Printer
52 scanner error. Turn off thenb on
52 is an internal scanner hardware error.
Unplug printer, wait 30 seconds, plug it in and power up.
Problem still there...make sure printer is plugged into wall outlet, not surge protector.
If error persists you will have to get the laser/scanner assembly replaced.
We arn't talking about the scanner/copier assembly at the top of the printer. This is the internal laser/scanner that is used for all your printing.
Jan 12, 2011 | HP LaserJet 3050 All-In-One Printer
Scanner error 5 on HP Color Laserjet 2840
Scanner Error 52 is a hardware error. If turning the power off , waiting 30 seconds and turning it back on does not solve the issue the the scanner assembly might need to be replaced. Another thing to try is make sure the printer is plugged into the wall not into a surge protector. Aside from that you may need to have the scanner assembly replaced.
Dec 09, 2010 | HP LaserJet 2840 All-In-One Printer
Error no is 51.22
go to this link, and read page 12 .. your error is listed as
http://www.partshere.com/Models/Q6455A/CLJ_2600nTroubleshooting.pdf
51.20 Error
51.21 Error
51.22 Error
51.23 Error
hardware error.
51.20 Error-black scanner error
51.21 Error-cyan scanner error
51.22 Error-magenta scanner error
51.23 Error-yellow scanner error
initialize.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
Laser scanners are not replaceable.
Replace the engine
please post positive feedback for me
Oct 17, 2010 | HP Color LaserJet 2600n Printer
Scanner error 5 turn off and on
Recommended action
  1. Verify that the connection cable is not loose or damaged. Replace the cable if necessary, and try the scan again.
  2. If the error continues to persist, contact Hewlett-Packard for technical support to troubleshoot the problem. 52 Scanner Error DescriptionThe device has experienced an internal hardware error. Recommended Action
    1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
    2. there is no much to do, is a hardware error, you must contact hp to your scan unit be replaced
Apr 07, 2010 | HP LaserJet 2840 All-In-One Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
52 scanner error on HP Color Laserjet 2840
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Mar 22, 2009 | HP LaserJet 2840 All-In-One Printer
52 Scanner error
52 scanner error means yoy got got an error with the scan assy, it could be many problems. If it not helps with turn off /turn on, try reset the printer. Turn off power press and hold * and #, turn on power, wait 20 sec and release the buttons. If printer not goes to ready, disconnect power cord when printer initialize and turn off power switch. reconnect power cord and turn on power switch. If you get the printer to ready state, upgrade firmware.
Oct 15, 2008 | HP LaserJet 2840 Printer
Error code on 5300 printer
turn off the printer
unplug the power chord at the back of the printer
wait for 5-10 sec.
replug power chord
turn on the printer
Jun 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
LaserJet 3052 All-In-One Printer Logo
203 people viewed this question
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
CheckitRight
CheckitRight
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
