Question about Lexmark X73 All-In-One InkJet Printer
My lexmark x73 scanner is locked in place
I have a lexmark all in one x73. the scanner is locked in place by a red button that pushes up to lock it in place. have had this printer for a long time and never had this problem?? any suggestions?
  • 1 more comment
  • BEBBEB Dec 20, 2007
    I have a lexmark x-73 3-in-1. Now the scanner and copy parts will not work. When I try to either copy a document or scan a document, after it reads the document it cannot copy or scan to the program. The printer makes a klack, klack, klacking noise and feeds out a blank sheet of paper or a blank screen in the case of a scan to program. It completes the process, but nothing happens. The klacking noise continues even after I turn the power button off, and does not stop until I disconnect the printer from the power source. Does anyone know what is happening here?
    I have disconnected and restarted several times. Same problem.
  • mollyokeeffe
    mollyokeeffe Oct 27, 2008
    same klackity klack noise and software all follows through but no image is picked up... Used to work beautifully now it is always his way...
  • mollyokeeffe
    same thing, klackity klack, the software follows through but no image is picked up! It used to work beautifully but now it is always the clackity clack and I assume something is stuck inside, a cable or something but how does one open to the inside of the scan bed itself?
I asked Lexmark support abd received the answere. this solved the issue immediately.
"Please note that there is a red lever on the back of the printer unit that locks the scanner. Make sure that this lever is located in the "down" position when attempting to power up the scanner."
Posted on Oct 28, 2008
    Genius:
  • 2,035 Answers
Epson perfection 2400 photo scanner stuck with flashing red light
You may have accidently pushed the LOCK button - this button is used to LOCK the carriage into place when moving the scanner to another location or shipping it.
Check for a button and the picture of a LOCK, it is usually at the back of the scanner, you can push it left or right, and you have an open lock and a closed lock picture under it. Make sure you didn't accidently push it to the LOCK position when holding the scanner - that loud sound means your carriage is locked and cannot move - once you set the button to UNLOCK this should solve your problem.
Jul 27, 2009 | Epson Perfection 2400 Photo Flatbed...
Lexmark 6100 will not unlock after unlock procedure is done.
Thank you for contacting Fixya.
Please ensure that the scanner is unlocked. The scanner lock is situated under the scanner bed towards the left. To unlock the scanner, please lift the scanner bed and push the red switch towards the back of the machine. Please try scanning again and let us know the results.
If the issue still persist, please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Sincerely,
Jeeth
Apr 15, 2009 | Lexmark X6170 All-In-One InkJet Printer
I have a lexmark x73 i'been instaling so manytimes on order to make the scaner to work but nothing I would apreciatte if you can give me some tips or help thanks
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X73) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X73 All-In-One InkJet Printer
Printer Carriage seems to be stuck.
lift the scanner bed and expose the underside of the scanner.
Sep 14, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x73 Printer
push the paper a little bit to help the printer to pull it correctly if not working then there is a problem with the rollers and that would be a hardware issue and needs to be fixed at the shop.
cheers
Sep 03, 2008 | Lexmark X73 All-In-One InkJet Printer
Faxing
WEll the x7350 is a fax and scanner and copier plus printer. Which x73 do you have?
Jul 27, 2008 | Lexmark X73 All-In-One InkJet Printer
Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Jul 14, 2008 | Lexmark X340n All-In-One Laser Printer
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
Lexmark X83 "Unlock Scanner" error
I had the same problem and the solution is this: There is a red lever switch by the power chord on the scanner/printer. Above this red lever switch is the drawing of a lock in the "locked" position and at the bottom this red lever switch is the drawing of a lock in the "opened (unlock)" position. The lever on the red switch should point to the "opened" lock symbol (unlock). It the switch lever is pointing to the "locked" position of the lock symbol, flip it to the "opened" position and recycle power on the scanner by removing the power chord for a 30 seconds. If the lever is pointing to the "unlock" lock symbol, flip it to the "locked" position and then back to the "unlocked" position and recycle power. Good luck!
Oct 13, 2007 | Lexmark X83 All-In-One InkJet Printer
Scanner will not scan
Set this options un der Control panel Scanner and camera. If fails try this, Uninstall everything HP Installed. Unplug the scanner. Then reboot. THen install the drivers and applications. Then reboot. then insert the HP scanner into the USB.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
242 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
