Question about Viking 30" Professional Select Built-in Electric Single Oven - VESO130
Viking VED0130SS double oven takes very long to reach temp.
The top oven seemed to start with the problem of taking a very long time to get to temp. After that happened we started to us the bottom oven that apparently has the same issue. The temp will get to 300 degrees fairly quickly, but then takes another 30-40 minutes to get up to 450 degrees.
barkencoa
  • 3463 Answers
SOURCE: Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Posted on Dec 02, 2008
  • 2976 Answers
SOURCE: oven doesn't heat up to the right temp--lower oven Viking Pro
Adjust the knob to the actual temperature. There are usually screws inside toe back of the knob for this purpose.
Posted on Mar 23, 2009
  • 832 Answers
SOURCE: Viking double ovens. Can both ovens be cleaned at
Unplug your oven, and clean both at once., Yes, you can.
Posted on Sep 26, 2009
  • 221 Answers
SOURCE: Elect Oven Viking - does not cycle temperature
It sounds like a weak igniter.
Posted on Jan 08, 2010
  • 122 Answers
SOURCE: have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
Posted on May 20, 2010
Our Neff U1421 double oven has a problem with tripping the main fuse when the main oven reaches 180 degrees. The oven is in manual mode not using the clock timer, can you throw any light on the proble
yes i know exactly whats wrong, one of your high accuracy temp sensors will have gone.
these tell the thermo what the sides & top of the oven temp is.
unscrew the oven from the base unit & pull it out, take the top off & you'll see them little round cylinder looking things with 2 wires coming off them(see link for pic) there screwed to the shell. the one that will have gone will no doubt have burn wires, or connections.
their sometimes called temp switch sensors
http://www.bi-metal-thermostat.com/photo/pl1619154-ip00_ceramic_bi_metal_thermostat_temperature_controller_for_micro_wave_oven.jpg
Sep 29, 2014 | Neff U1421 Double circotherm Electric Oven
Blodget zephaire G takes 2 hours to reach temp.
It hard to tell, please let me know what did you see and hear when turn on oven...
Jan 14, 2014 | Blodgett (ZEPHAIREG-DOUB) Double Oven
Have a viking professional oven and it takes too
May 20, 2010 | Viking 27" Professional Select Built-in...
Oven does not reach full temperature
Are you checking with a store bought thermometer or your recipe. If it is your recipe then ur thermostat might need a calibration or need to be changed completely if it is really off by more than 100 degrees. If it is 99 or less a simple calibration may just do it. If you have a steady hand. With your thermometer inside the oven and the door closed set at 350. Then take the oven knob off and take a small flat screw driver (really small). And insert it in the valve part where the knob was. With a flash light u can see the small screw. Turn it a hair at a time (1-2mm). Wait 20 minutes and see if the temp does rise. If not turn another hair. Repeat until 350 is reached. You must wait the 20-30 minutes for it to reach the temp. If all else fails changing the thermostat would be next. I do not recommend u do this alone. approx cost is: $400 - 500 front access, 500 - 600 rear access Good luck.
Sep 04, 2009 | Viking Ovens
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Aug 25, 2009 | KitchenAid KEBC107 Electric Single Oven
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 | Ovens
Oven doesn't heat up to the right temp--lower oven Viking Pro
Mar 23, 2009 | Viking DEDO205 Stainless Steel Electric...
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Viking 30" Professional Select Built-in Electric Single Oven - VESO130 Logo
180 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
