Question about Brother MFC-465CN InkJet Printer
The black ink comes out spotty while the colors are ok
    Scholar:
  • 150 Answers
I request try to follow the following steps:
1. Turn off the printer while holding down the 'Cancel' & 'Of' buttons on
printer till it shuts down.
2. After couple of times, you may get couple of bubbles out of black
tube.
3. This should fix the issue
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Posted on Sep 08, 2009
    Brigadier General:
  • 4,044 Answers
Your Black ink nozzles need to be cleaned and or serviced. If you have already used the Deep Cleaning solution and this is still an issue, try a new cartridge. If this does not resolve the issue you need to have the unit professionally cleaned and serviced. I believe Best Buy offers this service.
Canon mg5220 printer won't print black
Try this: take a small, sharp knife and make sure the air slit on the top of the cartridge goes all the way through the plastic.
You know that little tab you have pull off the top of the cartridge before inserting in the print head? There is a tiny slit under the tab to let air in, which is necessary to let the ink flow out. The slit is made very small so ink won't leak inadvertently out the top. Sometimes the slit doesn't go all the way through the plastic. When that happens, the ink can't flow.
I blew through that slit on a defective cartridge and no ink came out. I used a pen knife to open the slit (it doesn't take much) and then blew again. This time ink spewed out the bottom. My print test showed the black ink coming through. It was a bit spotty so I cleaned the print head and now the black ink comes out just like its supposed to.
Mar 13, 2012 | Canon Pixma MG5220 InkJet Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
Cyan ink is coming out purple. Tried putting in brand new toner but still have the same problem!
If the cyan or the blue ink is printing out in purple here's what you can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps Please rate if it worked Thanks!
Mar 31, 2011 | Brother DCP 165C Compact Color Inkjet...
Printer is printing the black color as light grey. Toner is already exchanged.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Jan 11, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
MP160 PIXMA - will not let me use black ink only -
u should be able to just take it and print if not there is some other problem
May 10, 2010 | Canon PIXMA MP160 All-In-One InkJet...
The black ink will not print, new cartridge, is spotty and not readable, barely prints black, printing color documents OK
I am having this problem too! prints color but not black, brand new cartridge, sorry I am no help, but looking for help myself!
Mar 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Oct 07, 2009 | Office Equipment & Supplies
Won't print black at all
Sounds like the JEt for the Black might have clogged or the print head has malfunctioned.
Feb 11, 2009 | Epson C64 InkJet Printer
The printer colors are not come out right.
Go to this link. Type "print nozzle test" in the search box and click Search. Perform a nozzle test, and if the colors match what are on the instructions, your print head and inks are OK.
(1) If the print head and inks check out OK, type "wrong colors on print" in the search box, and you will see several troubleshooting steps you can try.
(2) If the nozzle test colors are off, confirm that you are using BCI-6 inks for all three colors and the small black tank. You should only have a BCI-3 tank in the large black position. If you have all the correct inks, your machine probably needs to be serviced/ repaired.
Apr 29, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Brother MFC-465CN InkJet Printer Logo
162 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
