Question about Refrigerators
Hotpoint freezer fan noise?
I have a Hotpoint freezer/refer combo # HTS22GBMARWW. The top freezer has a fan that periodically makes alot of noise. My guess is that it's ice build up since it is not always there - comes & goes every few days. Assuming it's ice, any idea how to get rid of this problem?
    Genius:
  • 1,036 Answers
First check that you do not have a bagged item in front of it. I have done this myself - so is easy to do. The plastic bag touches the fan - making a noise.
Next - check freezer is defrosted regularly.
The fan is used to remove the moisture in the freezer when the door is first closed - freezing it to the evaporator coils - to be safely removed later.
Posted on Sep 08, 2009
My fan in my freezer makes a humming sound
it;s best to replace the fan / or find why the noise . it will probably stop due to this problem. and you may loose food . noises generaly are the first clues . and like i'v said before . if you can hear it it's running . but if your cant it may have quit . . then not cool and food loss . **** / hope this helped mm / feed back pls .
Jan 16, 2010 | GE Hotpoint Top-Freezer Refrigerator
What temp should my freezer be , also the fan in the top of the fridge stated making a noise when it stopped or started its cycle sounded like something was catching on the fans blades , then it stopped...
I like 0 to 10 Deg. F in the freezer.
As for the Fan. yes it could be ice or the fan blade hiting the shroud, sometimes the fan blade moves on the shaft and starts hiting the shroud.
Jan 11, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Freezer fan make a noise once in awhile
i have had some suces with removing the fan motor and soaking the BEARING AREA ONLY with # 10 w oil. the housing around bearing has a spong like material that feeds the bearing oil as it needs it if it only quiets down for a short time just get a new one a motor that is good luck
Jun 14, 2009 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
FAN IN THE FREEZER DEPT MAKING NOISE MAYBE FAN
if the fan is making noise it can also due to dust collected in the fan winks towards it end.or the other option is motor getting weak and needs replacement.
Feb 20, 2009 | Hotpoint HSS25GFP Side by Side...
Noisy
Check to make sure the fan is not hitting anything, if the fan looks good then on the back oof the unit is a relay, check that and make sure all is well. If both check out ok then I would get to work on the compressor and make sure it is not HOT to the touch and that it is operating correctly.
Please rate and let me know if you need more help
Feb 09, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Jul 18, 2008 | Hotpoint HTS16HBR Top Freezer Refrigerator
Hotpoint FFA70
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Jan 21, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFL49X Fridge compartment
GE Hotpoint has a history of bad fans and poor customer service. Unfortunate and a costly defect. Repair this yearly, forever or trash and buy new???
Aug 14, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
643 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
