Question about Car Audio & Video
Would a missing glow plug cause my 2.0 dti vectra diesel engine management light to come on and lose power when driving!
  • yadayada
    yadayada May 11, 2010
    no and yes.
    President:
  • 1,615 Answers
Yes
Posted on Sep 08, 2009
Engine management code po 381 on a nissan qashqai?
if it is a diesel engine the code refers to glow plug warning lamp---circuit malfunction===causes --wiring -- glow plug warning lamp---ECM
check the wiring / check the bulb in the light
Nov 08, 2015 | Nissan Cars & Trucks
My opel vectra 2008 diesel is Hard to Start when left for a period of time.iw will start when turned over a couple of times and with alot of white smoke from the exhaust.
If it doesn't do this when operating at regular intervals, I wouldn't be overly concerned. White smoke is normal for cold diesels, as long as it is only at start up and stops when warmed up. You may have a pump starting to lose its prime though. That would account for having to turn it over a few times after it has sat for a while.
Oct 07, 2015 | 2007 Opel Vectra 1.9
Engine dies on me then starts up again vaxhall vectra 2.2 dti estate
Not familiar with the vehicle however, if the "d" in "dti" stands for diesel, id check the large fuel filter; usually under the hood (bonnet). Possibly only needs the air bled out -especially if the filter has been changed recently.
Sep 02, 2014 | 2003 Vauxhall Vectra
89 Ford E350 Diesel - two problems 1) no power to instrument cluster, 2) diesel will not fire off without starter fluid...but the glow plug solenoid does click and wait light goes off
You should never use starter fluid when the glow plugs are hooked up. It can cause severe engine damage. You probably need to replace all the glow plugs and the glow plug controller.
Jul 06, 2014 | 1989 Ford F 350
1991 f 350 wont stay running7.3 deisel new injecters new glow plugs new fuel filter have to put gas on a rag and cover intake starts but u put into gear and dies
Many things to check. Wonder if this work was done to alleviate problem or problem was from doing the work.
Putting gas fumes in a 21:1 compression cylinder is sure way to ruin engine.
2 possible problems are losing your diesel fuel draw from an air leak in the fuel lines and an inoperative glow plug timer.
When you change a fuel filter you lose the vacuum lock that is in the fuel lines. Some mechanics add fuel to the new filter to remove some of the air and promote fuel draw. The O rings on the injector lines are a special type which resists petroleum products. Using cheap O rings will cause problems.
Glow plug timer-there is a power Relay to the timer and the timer itself is a type of Relay. You should hear clicking noise and lights should dim as timer provides power to the glow plugs.
Other things to check would be the Vacuum pump as Diesels work differently than gas engines and require a pump to supply Vacuum. Covering the intake suggests engine needs a Vacuum draw.
Weak fuel pump. Too weak to pressurize or draw fuel. Can be measured with pressure gauges.
Really bad rings could also cause symptoms.
Would be interested knowing what proved to be wrong.
Sep 29, 2013 | 1989 Ford F 250
Vectra dti steering resovour where is it
In the engine bay at the front of the engine? It should have a black cap that says "power steering fuild" or something along those lines on the lid. Look around the engine bay till you find it really. There are not a lot of resorvours with caps in the engine bay and they should all be labeled. Hope this helps
Dec 04, 2012 | Cars & Trucks
Glow plug light
Glow plug light? I didnt know Ford made a Diesel Focus?
May 24, 2010 | 2003 Ford Focus
P1677 code on ssangyong stavic 2.7l turbo diesel. Engine light comes on and vehicle loses all power and coasts to a halt. Also has 3 open circuit glow plug codes.
p1677 code on ssangyong stavic 2.7l turbo diesel. Engine light comes on and vehicle loses all power and coasts to a halt. Also has 3 open circuit glow plug codes.
Nov 18, 2009 | 2005 Mercedes-Benz M-Class
Heater plugs for nissan terrano 2
i have a nissan terrano 2.7 dti heater light not coming on some times dose and some times does'nt and it wont start
Oct 06, 2009 | 2002 Nissan Pathfinder
Mondeo diesal 2002, glow plug light
Hi
The glow plug coming on on the Diesel Mondeo is an engine management fault indicator. The car goes into "limp mode" when this happens or in other words safety mode is triggered. This explains your loss of power.
To find the cause of this light coming on - the car will have to go on an OBD scanner at a service shop which will read the codes stored in the cars computer and give you an answer as to what is causing the fault to show.
Hope this helps - please remember to rate my answer as ratings are important to me as an expert on the site. Thank You.
Jul 13, 2009 | 2000 Ford Focus
Car Audio & Video Logo
210 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
