Question about kawasaki PVS-10921 Portable DVD Player
Car charger My car charger shorted out and I am trying to find one that will work.  The problem I am running into is that I can't find a connector that works that fits into the dvd player.  Any suggestions?  Thanks
  • lorenacheney Nov 28, 2008
    I lost my car charger. Where can I order one or find one???
  • 3 Answers
The website for this player is
www.1800customersupport.com
Posted on Jan 11, 2008
My RCA 8" tablet for some reason has stopped charging properly. The device will flash a few different screens, but no charge. I tried to reset it but it did not work. What do I do?
Please check everything in the "charger chain"
The charger, the cable and all connectors. All connectors should be clean and shiny. When you think there could be some dust in one of the connectors, try to blow it out with a bellow photographers use. Don't try to remove anything with sharp or pointing things, You could break a contact or damage the connector. Check the charger, if it still is working (giving enough power) and check if there is not a weak place in the cable. Don't forget the connector in the tablet.
Jan 31, 2015 | Tablets & eReaders
Mac shorted out
try with another charger buy one at bestbuy if its not working return it. Your logic board may be shorted out
Oct 16, 2013 | Computers & Internet
95 jeep grand cherkee clicking noise passenger side under dash radio won't come on while car is running or key in start position but will in acessory position also interior lites blink while car i
try this.. disconnect the vehicle battery entirely, connect a 10 amp battery charger to the car connectors matching the terminal leads..and power the car with the charger..you should hear a hum or buzz in whichever relay or circuit breaker is bad.. replace this relay and the lights and stuff should work..the charger will not direct-short but the guage may go full over indicating a malfunction..or extreme load.. maybe a window switch might be fried..you should be able to hear any issues as long as power is coming from the charger only...repost findings..
Jan 27, 2013 | Jeep Grand Cherokee Cars & Trucks
My vtech 5831 handset charger won't charge brand new batteries
did you check your charger if it is working?mostly of the charger are malfunctioning its chord or wires.
also try to clean the charger connector of the unit where you can see at the bottom..Clean it with cotton buds to wet of rubbing alcohol.you just rub it to the connector of the handset itself and the connector of the charger itself.
Oct 27, 2009 | Vtech VT 5831 Cordless Phone
Advent laptop, been on holiday for a week, it has not been used in that time. It won't power up with the charger plugged in or not, the power lights are also off. Charger is broke but pc world techguys...
Well, if the chargers don't work that leaves a problem with the power connector on the motherboard. If the socket was or is loose it could be causing a short on the board. The cost of the motherboard will most likely rule out any thought of replacing that. If you have a working charger try removing the battery and with the power disconnected hold the power button down for 60 sec. Then plug the charger in and try to turn the PC on. I've seen this work before and it makes no sense that it does but you can try it. The only other problem I can think of that might cause this symptom if the lid cutoff switch is stuck in the down position and over riding the power switch.
Oct 12, 2009 | Advent Netbook
Low or no voltage for the two fan connectors on the motherboard. Fans will not run when attached. Have to use a direct connector from the power supply. All voltages from the power supply check okay.
there might be a short on the mother board where the fan connectors are.try different fans.if they don't work then there is a short.the fans work the same way on the lines from the power supply.
Aug 04, 2009 | Tyan Trinity KT S2390 Motherboard
It wont charge!!!!! (lg cookie kp500)
may be ur charger connector is usb supported. then may be ur charger or charger cable damaged. plz change it. or ur charger ic has damaged for short circit..
Jul 15, 2009 | Lands Phones
Gateway MX6447 Not Charging Correctly
probably the connector on the motherboard has come loose. i have had to solder a couple connectors back on and it isnt really that hard to do, but that is probably the problem.
Jan 19, 2009 | Gateway MX6447 Notebook
Car kit on display screen
It's actually something wrong with your phone. The connector on the bottom of the phone may have gotten wet. If you are comfortable taking the phone apart you can clean the connector w/ 99.5% isopropyl alcohol and a soft bristled brush. Good luck.
Sep 05, 2007 | Cell Phones
kawasaki PVS-10921 Portable DVD Player Logo
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
