Question about Toshiba (HDD2188) 80 GB Hard Drive
Hard disk problem
Hi plsss somebody help me i have just formatted my hard disk drive using the cmd prompt, i got it right but when im trying to use it the system can recognize the drive but i can't get any access to it? i chnged the BIOS set up but i cant see any drive letters of my disk? by the way i forgot to mention i am using two HDD, i can accesss to the other 1 and i've already set the BIOS setup to w/c is the master and the slave. As i've said the system can detect my 2 HDD but the problem is that i can only use the master HDD and also the system is assigning both of them master? what should i do????PLSS!!! somebody help me! Thanx,s In Advance!!!
  • Anonymous Mar 25, 2014
    hi i can't format my entire hard disk using cmd it says select volume and tray again some help or advice thank's
    Sergeant:
    Champion:
  • 317 Answers
Change the other HDD to either Cable Select or SLAVE.
Then make sure you partition it correctly, Windows does a decent job at it.
Right click on My Computer, go to Manage, then under storage, click on Disk Management; you should see the HDD here.
Posted on Dec 09, 2007
  • Baja Data / Jay Arias-Chavez
    Was your problem solved? Do you have more information or questions?
    Please let us know so we can help you better. Better yet, give the solution a rating! :D
    Thanks!
Reformatting HCS725032VLA380
Is it your primary hard drive ?
Reformat hard drive to NTFS Windows XP allows you to easily format the hard drives with its inbuilt utility. Formatting the hard drive would forever delete all the files stored on it. There are two ways in which you can format the hard disk partition - from My Computer and from DOS. You cannot have a NTFS partition with allocation unit s above 4096.
Click on "Start," and then click on "My Computer." Right-click on the disk partition to format and then click on "Format." Click on the "File System" drop down box and select "NTFS." Click on the "Allocation unit " drop down box and select an allocation . It is recommended that you select the "Default allocation " option. Click on the "Start" button. b> Format the Partition from DOS b> Click on "Start," and then click on "Run." Type "cmd" in the 'Run' dialog box and then press "Enter." Type "format drive_letter: /FS:NTFS" at the command prompt and then press "Enter." Replace the 'drive_letter' here with the letter of the drive that you want to format (for example, format e: /FS:NTFS). For help on advanced formatting options, type "format/?'more" at the command prompt and then press "Enter." Keep pressing "Enter" as you read on. Hope it helps
Jan 24, 2013 | Hitachi CinemaStar 7K500 HCS725032VLA380...
I have Samsung HXMU050DA Portable HDD. My Notebook is feel it, but the Files nothing. "Your Hard Drive is Not formatted! Please formatting now?". I would like to Not lose My Files and datas....
If it asks to format the drive one of two things is most probably
  • The hard drive comes with software used to unlock the drive. If yes run the software and unlock it. If no next...
  • The file system is damaged. You can try repairing the file system by the following
  1. Open a command prompt (Windows key), type cmd
  2. type the following without the quotes "chkdsk [volume] /f" replace [volume] with the drive letter followed by a : so if Im checking drive E then it would be chkdsk E: /f
  3. If your running windows vista or 7 you will need to replace step 1 with (press window key), type comm and right click on command prompt and select "Run as Administrator", click yes.
  4. If you still can't get into the drive then you will need to either format it or just replace it as it is probably failing
You can download this http://www.ntfs.com/disk-monitor.htm and test the hard drives health to help you make a decision of whether or not to replace
Comment back if you need more assistance
Aug 30, 2011 | Samsung HXMU050DA/M32 500 GB USB 2.0 Hard...
Cannot format my 2 gigabyte usb
Start ->Run -> Cmd .Hit enter button.
Then command prompt will appears on the screen.By using format command you can format your flash drive. Then type format D: /FS:FAT32 Here D is a drive letter.More information about format command in command prompt type help format.
Aug 03, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb shows 4 MB space instead of 4GB
hi, if you do not need data,go to cmd prompt format your pendrive using this cmd "format Z:"
then see your size
May 25, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
La Cie USB hard dirve its lighting intermittently red and yelow and the computer not recognized
Plug your usb drive into your computer. Then right click on my computer and select manage. Select disk management in the left pane. scroll down to look for your external drive in the bottom pane. You might need to initialize the disk by right clicking the gray area to the left of your disk on the bottom pane. If its already initialized you should be able to right click the disk just to the right of where you just clicked and select format, making sure to assign a drive letter and do a quick format of ntfs through the wizard that pops up. If the drive is labeled GPT protected you'll have to convert the disk to MBR by using the diskpart command. Go to start then run and type cmd and hit enter to bring up the command prompt.
  1. Type diskpart and hit enter
  2. Type list disk and hit enter and find your disk in the output
  3. Type select followed by your disk's number, for example "select disk 1"
  4. Type clean and hit enter
  5. Close the command prompt and now you should be able to initialize and format your disk.
Mar 04, 2011 | LaCie F.A. Porsche (301177) Hard Drive
Win 7 Ultimate will not recognize my LeCie big disk extreme back up drive. LaCie support was no help.
Mar 03, 2011 | LaCie Big Disk Extreme (300797U) 1000 GB...
Computer wont recognize external hard drive
try to format the external HDD using command prompt..... type "cmd" in start & search box and hit enter... command prompt will be opened... Now type "format X:" where X=your external hdd drive letter.... if it does not format then right click on my computer icon> goto manage >select Disk management> select the external drive> right click and delete partition > again right click and select create partition > again right click and select Format drive.....
this will fix the issue....
Apr 20, 2010 | Western Digital My Book Essential Edition...
I have my desktop formatted,,and it turns right,(that's what i thought) but after sometime it does not start i just have this prompt saying start windows normally but it does not..and i tried restarting it...
Hi, it seems Windows is not installed well or the hard disk could be faulty, the first step could be to check data and power cables among motherboard and power supply to hard disk and if that's OK, try to do a clean Windows installation, if this fails maybe the hard disk has the boot sector physically damaged and it's better to replace it.
Jan 16, 2018 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
WD3200ME-01 Passport size diskspace problem
To format the drive to allow files larger then 4GB: Open up My Computer, Right click on the Western Digital Drive. Select Format from the list. Under file System, select NTFS. Under format options Check Quick Format. Click Start to format.
Warning! Formatting will delete all data and files on the drive. Make sure to transfer all your files to another drive before preforming a format!
Jul 03, 2008 | Western Digital 320GB MyBook External USB...
Hard disk problem
First u should format disk from disk management mmc snap or from command prompt.without formatting a disk's properties says 0 bytes used and 0 bytes free space.
Sep 03, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Toshiba (HDD2188) 80 GB Hard Drive Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
