This is most likely a damaged pipe going to the low pressure sensor. This sensor determines when to turn water off by the pressure built up in a tube. If there is a damaged pipe - it wil overflow.
Turn off and disconnect machine, then remove access pannel to inspect all small bore pipes for damage. Check pressure valve for correct operation.
If it leaks at times other than filling, and water level seems ok, then it could be a damaged top or bottom seal that needs identifying and replacing.
If it leaks constantly it could equally be a damaged rubber pipe between drum and pump.
You really need to remove an access pannel - and just observe operation without putting your fingers in thereto spot it.
Hotpoint VBXR..... top load washer,my wife noticed water leaking from washer and isnt goin thru spin...
(More)
Hotpoint VBXR..... top load washer,my wife noticed water leaking from washer and isnt goin thru spin cycle correctly in other words its leaving cloths very wet in end.I pulled front panel and watched it operate,it does seem to drain fine but I did notice a water leak from bottom of tub where the aggitator/axle goes into tub.how do i fix this and why would it not do spin cycle correctly.Gotta fix soon wife is pregnant and washer is outside so water may freeze on carport fllor.
my washing machine is just humming like the motor is running but it does not wash or spin is that...
(More)
my washing machine is just humming like the motor is running but it does not wash or spin is that just a belt?
