Question about Toshiba Televison & Video
Screen is blank but can hear dvd reading and power
Toshiba portable dvd player sd 1900 screen is blank but can hear dvd reading and power supply is fine any suggestions??
  • 2 more comments
  • manney Sep 09, 2009
    Iear the dvd player turning but no sound and no light came on the screen at all it is blank. There is power and i have tried another battery. I have two of these players one works one doesn't.
    by blank i mean pure black no color or anything
    ok it is the display screen i plugged in the ac out and into the tv so and it is showing on the tv. Anyway to fix the display cable? How much would it be verses sending to toshiba for 95.00 or another repairman do should i just buy a new one?
    thanks for at lease diagnosing the problem
    great to finally have the answer if i could fix it or not thanks for the help
  • 178 Answers
Couple of Questions;
1. Do you hear Sound ?
2. Is the counter moving ?
3. When you switch it on you should see the screen backlight come on, the screen will get just a little bit lighter, and do you see a splash screen?
Posted on Sep 09, 2009
  • 1 more comment
  • zapdbf Sep 09, 2009
    Your issue will be difficult to pinpoint without some more diagnostic, below is how you can determine why you are having this trouble.
    1. “It could be the lcd display” - Diagnose this by using the card reader and try to playback images off of the card reader or usb interface. If you don’t get a display from this, It is a good bet that the display is not working.
    2. Playback an audio cd, if the audio cd will playback fine it is a good bet the dvd player is working fine.
    I am leaning towards a display problem, and the most common reason for the display not working is a damaged flex cable inside the unit, there is a flexible cable that runs from the dvd part up to the display, this can become damaged over time from opening and closing the unit.
    In regards to the dvd player, even if it is spinning- this is not an indication that it is reading the disk, because it may just be trying to focus onto the disk, you usually will hear a tick sound if the lens is attempting to focus. If you playback a CD only and it will play back fine you know that it is gaining focus(focus errors are the most common failure for a cd or dvd player).
    One last thing that you can try, the video out jack may have a problem, try inserting and removing a jack into the video out and see if the video will flash on.
    Post back here if you cannot determine the issue i will help with this issue further.
    The retail on these are only around $149.00 i believe, so i would not send it to Toshiba for $95.00. A local repair shop may take it on - our shop would. If it is a cable i could see the repair running around $50.00 if it is the display it would prohibitively expensive to repair. Usually shops will charge a diagnostic fee for a non-repair of about $25- $40 depending on the shop.
    The bottom line is if you take it to the shop you will gamble the diagnostic fee on getting a reasonable repair cost.
    If it were mine, i would just replace the unit, and use it as an extra dvd player for the house
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Hi When I turn ON my Toshiba SD-P1900 player,with
I brought my dvd player to the Toshiba repair center. To be continued...
Nov 26, 2009 | Toshiba SD-P1900 Portable DVD Player
No valid DVD displays on my Toshiba SD-P1850
Most portable dvd players will not read burned dvd/cds. Please be sure to use originals in your dvd player. If you have a user's manual it should tell you if your player reads CDR's or DVD/RWs
Aug 07, 2009 | GPX PDL805 Portable DVD Player
My toshiba portable dvd player (sd-p1900) won't play discs. We have two, and the other one works, so it's not the disc. When you put a disc in, it doesn't spin, and it says that there is no disc.
i had this same problem, its likely a disconnected ribbon wire off the drive, One I plugged that in it read/spun the disk, now I just need to get the screen to stop being blank white heh. Good luck ^^
Jul 14, 2009 | Toshiba SD-P1900 Portable DVD Player
No picture
hi!
you can download the power dvd player.
because other computer you can play and hear the sound but no picture.
PS:
pls rate if is invaluable solution rate me fixya.
thx
May 22, 2008 | Toshiba SD-P1400 Portable DVD Player
No screen display while DVD plays
optic lense reader are dirty need cd cleaner
Jan 03, 2008 | Coby TF-DVD7005 Portable DVD Player
Televison & Video Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
