Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
JD LX173, Kohler Command OHV Engine keeps droping mounting bolt
I have a JD LX173 with a Kohler Command OHV engine and it keeps vibrating out the mounting bolts. I am hoping the thread is not stripped. What are my options to fix and what if any problems might I encounter?
    Genius:
  • 1,036 Answers
Use a thread locking compound on the bolts - and torque them to the correct spec.
This will prevent them shaking out.
Posted on Sep 08, 2009
  • oldhat2u Aug 13, 2011
    What size are the bolts? Fine or coarse thread? Thanks!!
Kohler command 18 not getting gas to carb and fuel pump is working fine
Tankairiation, tankfilter ,tapfilter pourous hose floatchamber ,nozzle , gaskets
Mar 19, 2016 | Kohler 18 Hp OHV V-Twin Command Engine
Why oil consumption on kohler command 20
Either badly seated oil rings or PVC valve is stuck open allowing oil to enter through carburetor.
Oct 20, 2014 | Kohler Command OHV Horizontal Engine with...
Safety switch on brake handlechecks ok but motor cuts off when released
check clutch safty switch or seat safty got to be one of those switches
Oct 03, 2014 | Kohler Engines Kohler Command OHV...
What is the head bolt torque specs for a Kohler Pro 25HP V-Twin engine?
Go here and look up your engine model
Owners Service Manuals
Here is a Manual for the Kohler Command Pro CV26
http://www.kohlerengines.com/onlinecatalog/pdf/24_690_02_EN.pdf
The picture shows the torques of the Kohler Command Pro
Aug 19, 2014 | Craftsman Garden
18 hp kohler engine starts but doesn't keep running!!!!
You put in a question about your ride on. What is it you need?
Aug 15, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
I have a Kohler Command 25hp (CV730) mounted in a JD G100. The engine is leaking oil something fierce out of the bottom end and I need to get the clutch assembly off. Does it rotate clockwise is the...
You will have to hold the flywheel for removing the clutch. It may require removing the blower housing.
I use an impact wrench which loosens the bolt w/o holding the flywheel.
It's 99% a regular bolt (turn ccw to remove) since left hand threads cost more to buy the bolt and tap the hole and small engine stuff is made as cheaply as possible.
Jan 22, 2018 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Is it possible to replace my Kohler Command CV491S with a Kohler Command PRO CV620?
technically it is possible to do a heart trnasplant
all you need to check are the mounting flange holes or be able to drill new holes in the mower frame
and next the method of attaching the drive pulley or pto to the crank shaft has to be considered
Jul 03, 2017 | Garden
Kohler command 20 twin engine - no spark
If there's no spark, then either the spark plug has come into contact with gas, or the ignition coil is bad. Try either replacing the spark plugs, or removing the old ones and seeing if the tips are damp.
If replacing them doesn't work or the plugs are dry, then try replacing the ignition coil.
Feb 15, 2013 | Kohler 20 Hp OHV Command V-Twin Engine...
Kohler Command 12.5 OHV (starter?)
You should properly test the battery. A dead cell in a battery will absorb the current that you are trying to supply by jumping.
There may be a fault in the wiring system, thus not allowing enough current to properly supply the starter. Construct a way to temp. connect the positive jumper cable lead to the tractors battery cable connection on the starter that will not short circuit and connect the other poss. end to your trucks poss.battery terminal and then connect the ground lead as normal but to the tractors frame, then attempt to start. If this allows the starter to operate properly then disconnect your jumpers and Inspect the positive and ground wires for insulation cracks, blisters and corrosion. Also check the connections for being clean and tight.
You could also remove the spark plugs ( to release compression that will allow the engine spin free) to see if the starter will then turn the engine.
If all fails, sorry to say, your starter may be weak and in need of replacement.
Good luck
Aduz
Mar 25, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
530 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
