Question about Honeywell Heating & Cooling
I can not change the thermostat setting on the unit. Whenever I try to change it, it reverts back to the previous setting.
    President:
  • 1,015 Answers
The thermostat will display the current tempature in the room. When you press the buttons to change the tempature and you see it change back it is probably going back to the room tempature display but still keeping the temp you set it at. Also make sure the "hold" feature is set or the temp you choose can change at different times during the day due to the programmable features built into the thermostat.
Posted on Sep 08, 2009
I keep trying to hook to my wifi and it wants to change my IP address continuously. I had to change the settings to "static" and type in my IP address. Unit connects initially and then reverts to an
Keep the router to supply IP address using dhcp mode. Increase the lease time to 24 hours and don't forget to bind your device mac address with the dhcp IP in the router. This way it will always get the same ip from the router.
Dec 30, 2014 | Computers & Internet
My Honeywell T8001C doesn't allow me to change the indefinite temperature hold for some reason
It sounds like the thermostat is malfunctioning; the Set should not be flashing at all, only the Hld should show after pushing the hold button.
Do you have a new battery in the unit? Is it set to Heat or Cool? Is it already programmed for current Time/Date and does it have a schedule programmed in already? If you've lost the user manual it's here: https://customer.honeywell.com/resources/Techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jul 06, 2014 | Honeywell Programmable Thermostat Heater
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
Hi, Monitor is acer x193hql 18". Have just reformatted my HDD and installed XP (Was XP previously) Resolution now seems to be stuck at 800x600. Have tried Control...
So you say you formatted hey? This seems to be a problem with the GPU (Graphics Processing Unit) and not the monitor itself. Try re-installig and VGA drivers for your graphics card, if you are using on-board graphics, then install the VGA drivers that came with the motherboard.
Nov 15, 2010 | Acer AL1916W 19" LCD Monitor
I cannot change my 'Memory in use' from Phone Memory to Memory Card. 'Changing message memory in use' is appearing, but after that, nothing happens, it's still using Phone Memory as storage.
are you doing it for messages, if yes, it works properly but whenever you remove your memory card it reverts to phone memory, you have to revert setting back to memory card
Jun 27, 2010 | Nokia N73 Cellular Phone
When we have a power bump the unit reverts back to factory settings, Can a ups be added to the control board to eliminate this problem?
Not sure why your unit would reset to factory settings, it's usually the thermostat settings that control the unit and resets when you have a power failure. Most thermostats have a battery in then to power the thermostat during a power failure. They usually only maintain the power from 15 to 30 minutes to maintain your settings, before defaulting back to factory settings. After every power failure you usually have to replace the batteries.
Feb 26, 2010 | Samsung AP500PF Air Conditioner
Machine does not turn on. power is going to unit.
Hi
Depending on age you could have a few problems all fixable.
1. You could have a fuse or thermostat with a reset button. Some are on the back or side of the boiler.
2. you could have a power filter that is bad.
3. you could have a board that is bad. I have boards
Dec 13, 2009 | Saeco Vienna SuperAutomatica Coffee...
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
My thermostat will not change the temp when trying to change
tHE TIME PERIOD SETTINGS ARE ONLY TEMPORARILY OVER RIDDEN. oNCE THE TEMP YOU SET IS REACHED AND THE UNIT SHUTS OFF IT DEFAULTS TO THE PERMANENT SETTINGS ON THE CLOCK.
Jun 05, 2009 | Honeywell Programmable Thermostat Heater
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
Heating & Cooling Logo
178 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
