Question about GE Refrigerators
High pitched noise
Make a high pitched noise only when the fan and compressor are running. Stops when they are not running. It is model # GSS25KGPHBB.
  • 286 Answers
Then you will need to stop the fan and see if the noise is still there. If yes then its in the compressor. If it goes away then replace the fan
Posted on Sep 09, 2009
Frigidaire refrigerator only 6 months old making high pitch noise constantly after door has been opened. What is causing this?
Hello friend, thank you for your post!
Based off the information you have provided your Frigidaire refrigerator is making high pitched noises after the door has been opened. With our current refrigerators the new modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound. If you feel that further assistance is needed please contact your manufacturer for any warranty coverage. -Matt
Feb 02, 2016 | Frigidaire Refrigerators
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
High pitch intermittent noise
Check your fan and clean it up
Sep 08, 2014 | Samsung RF4287HA
Why does my new Frigidaire FFHT1826 make a high pitch noise
Thank you for your post, friend!
Based off the information you have provided it sounds like you are hearing the compressor come on. In the newer, high-efficiency compressors they operate much faster than the older models and some may put out a high pitched hum or pulsating noise. I hope this helps. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
Hss25gfpdww The unit makes a horriable high pitch whining noise a
I am not posotive, but it sounds like you may have a piece of debris stuck in the fan underneath. You can check if you pull it out from the wall, make sure you unplug it as to not have the fan come on while you are toying. But thats what it sounds like. If that is not it, I am sure you could locate the noise with it pulled out from the wall, and go from there, Possibly your compressor, but sounds like the fan the way you're explaining it. Good luck
Feb 14, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Refrigerators Logo
591 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
