Go to http://www.lexmark.com and click on the driver finder under drivers and downloads, you should be able to find and download the correct software there. If you need further assistance they have a toll free helpline 1-800-332-4120 you can call 8 am to 11 pm weekdays and 11 am to 8pm Saturday and Sunday Eastern Daylight Time
I've download and installed softwer printer Lexmark Z2320, but after installed appear z2300, Is driver z2320 the with Z2300?
SOURCE: My Lexmark Z2320 series
First thing; check your power supply. Make sure it is plugged in securely on both sides. Do you have a DC voltage coming out of the DC power connector that connects to the printer? You can get a DVM (volt meter) for 10 bucks or so at Harbor Freight to verify that your power supply is working. Good luck!
SOURCE: driver for lexmark printer Z2320 is not available on their site
http://www.siliconguide.com/drivers/device/46/
download from here.
SOURCE: lexmark z2320 powerlight blinks and printer won`t work
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
SOURCE: i lost the cd installer for lexmark z2320 i need
I suggest not to plug the printer to your computer yet. Download and install the software first. Here's the link to the Lexmark website for the available Z2320 drivers. http://bit.ly/bA5tOo. Click on the Microsoft, Macintosh or Unix/Linux dropdown found below the page to choose the version of the operating system of your computer. Download and install the software. Follow the instructions on the software. Hope this helps.
