Question about HP LaserJet 3600n Printer
The printer shows low on black yet prints solid black pages when we send normal documents to be printed. What do I do? Note: the black toner level is low and is due soon to be replaced - but it is not empty. Tks
  • deeann600 Sep 08, 2009
    Why does my HP Laser jet 3600n print solid black
    pages????
    Tks
    Sniper:
  • 58 Answers
Yes it start giving the warnings if it still have the ink just to make sure you get the new cartridges well before it gets completely dried
Posted on Sep 08, 2009
    President:
  • 1,187 Answers
The message is just a warning....
In order to "extend" the print life of the toner:
1. Remove the cartridge fromthe printer.
2. Hold the cartridge by the ends using both hands.
3. "Rock" the cartridge like you are moving a steering wheel clockwise/counterclockwise...
4. Now "Roll" the cartridge in a forward/backward roll..
5. The toner is now evenly distributed in the cartridge...
6. Put cartridge back in printer... The "low toner" warning may go away!
7. Wash hands...
Hope this helps!
Trying to print documents, white background with black typed words. Problem I have is the printed documents have solid dark blue and solid black ink and the words don't show.
Are the ink cartridges installed in the correct colour order?
Have you printed a test page through the printer's own control panel? What was the result?
Open a new document, using the default settings. Key in some test text. Try printing. What is printed?
Jan 06, 2015 | HP Office Equipment & Supplies
Hi when printing black or grey outside edges
sounds like your black toner cartridge is getting low or not filled evenly. To fix this until it get a bit lower on toner just take the cartridge out and holding it up right give it a few shakes side to side. The will spread the toner power out inside and you should be printing normally again.
This can also happen if you moved or bumped the printer. Usually you only see this when the toner is low or after you print a lot of pages. Most text is in the mid of the paper so thats where the toner get s used the most.
Oct 23, 2009 | Samsung CLP-350N Laser Printer
Dell 1720 lazer printer only printing solid black pages
The corona wire is not charging the drum properly. Try pulling the toner cartridge out and then re-seating it. If this doesn't work, try a new toner cartridge as the corona wire is usually included in the cartridge.
If you are using a refill toner, there's an outside chance that the supplier put toner with the wrong electric charge in the cartridge. Again, changing the cartridge should fix this(assuming the replacement is from another batch).
Jul 25, 2009 | Dell 1720dn Laser Printer
Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
May 01, 2009 | Xerox Phaser™ 6180DN Laser Printer
Low Toner Warning
Turn the unit off. Remove the cartridge and shake it back and forth. Ten place it and turn the unit back on. Also you can reset the counter on the cartridge, go to UNI KIT and look under Brother TN 110 refill support. These people sell refills. The ink you get with he printer is minimal. Also turning the printer off and back on will help with resetting. I found that there is plenty of toner left when the warning comes on.
Feb 28, 2009 | Brother MFC-9840CDW Laser Printer
Printer prints black line on every page as well as the document
a solid line on every page is either a defective toner cartridge or imaging drum. since you did not specify your printer type and model, I can only go by general print quality generalities. A Void can be caused by other things, such as a bad printhead or dirt on the print head, but a line is usually caused by a defect on the imaging unit, developer, or toner cartridge (on units with a toner cartridge, the developer and imaging unit are enclosed in the cartridge).
Sep 23, 2008 | Office Equipment & Supplies
HP K550 Prints Solid Gray Boxes Around Items
Hi drglass1 -
13,000 copies - that's awesome! although you've surely fixed this problem by now, for future refs or someone else searching for an answer... you might find this ref hp support helpful. happy printing!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00458018&lc=en&dlc=en&cc=us&lang=en&rule=35557&product=501369
Step 4: Clean the printheads
If the print quality is still bad, clean the printheads:
1. Make sure the printer is loaded with unused white paper.
2. Open the printer Toolbox and select the Printer Services tab.
3. Click Clean Printheads . A Clean Printheads window opens. Click Level 1 Clean .
4. Examine the page that prints for print defects.
a. If there are no defects, click Exit . Stop troubleshooting here .
b. If there are defects on the page, click Level 2 Clean . 5. Examine the page that prints for print defects.
b. If there are defects on the page, click Level 3 Clean . Note that Level 3 cleaning uses a lot of ink – it is not recommended if the cartridges are low on ink. - JW50
Sep 17, 2008 | HP OfficeJet Pro k550 Printer
SOLID BLACK PAGES?
in laser printers, theres a charging corona wire that gives the paper a 600v positive charge which attracts the toner. once the paper hits the drum, a laser with a 600v negative charge is shot at the paper which discharges the paper and the toner isnt attracted to that area anymore.
either the laser is malfunctioning and not shooting a beam at the drum which would make all the toner go to the paper, or theres something wrong with the toner cartridge.
try going to the brother website and downloading the driver again (cheap and easy) and if that doesnt fix the problem, replace the cartridge, i know, not cheap. if neither fixes the problem, call the brother support line and see what they can do for you. maybe the warranty will cover the repair costs for you.
hope this helps.
Aug 24, 2008 | Brother HL 1230 Laser Printer
Lexmark E250dn laser printer
Reinstall the drivers and see if it works.
Otherwise unplug the printer from the power and leave it without power for 10 minutes. Than plug it back in and let me know if it helped.
Feb 08, 2008 | Lexmark E250dn Laser Printer
HP LaserJet 3600n Printer Logo
280 people viewed this question
Seeker5211
Seeker5211
