Question about Samsung Instinct Cell Phone
No picture id
When people call me it keeps coming up as "cell phone, mi" with a confirm button. it used to show who was calling me and their picture ID. Out of nowhere it started to do this. please help
Our phone just stopped showing caller ID one day. No just shows "external" and no number.
It is my understanding the caller ID feature comes as part of your telephone service and your phone only displays what comes through. So either you changed the subscription which means you dropped the Caller ID feature or your BT plan does not have it anymore. Best to call BT and confirm.
Sep 01, 2014 | Siemens Gigaset Sl910a Piano Black, Sealed...
How do i block incoming phone call from a uniden cordless phone
  1. Block an Incoming Call
    • 1 Wait until your phone rings and displays the caller ID information 2 Press the "Block" button on your handset.3 Press "Menu/Select" or "Block" to confirm your decision.Block in Standby Mode
    • Press the "MENU" button on your phone's handset.
    • 2 Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
    • 3 Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice
Oct 14, 2011 | Uniden Cordless Phone
On Samsung jet s8000 Incoming calls display unknown caller message, but call log shows ID
Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Apr 26, 2011 | Samsung Jet S8000 Cell Phone
How to set picture to caller id for motorola rival a455 Does any one know how to set the picture of yor contact to your caller id so when they call the picture shows up as your caller id. on the Motorola...
Go to the person's contact you wish to set a picture to. Select that contact and then select edit. Scroll down to where it says picture. Click Set ( left soft key) then it will give you a choice on taking it from your pictures, downloading a pic or some other choices. Choose the one you want and save. Your picture should come up when that person calls you or you call that person. Hope this helps!
Oct 14, 2009 | Motorola Mobility Rival A455 Cell Phone
No caller id on Blackberry 8800 when using bluetooth headset
yes it will happen when u connect with your Bluetooth you have to use your Bluetooth only no u can see anything on your phone
May 16, 2017 | Verizon Communications BlackBerry Pearl...
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
Apr 26, 2009 | General Electric 28811FE2 Twin Cordless...
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Hao to delitet pictures from the phon lg darevx9700
go to your photo's. select the picture. delete should be on the bottom right. click it and confirm.....the default pictures can't be deleted though
Jan 22, 2009 | LG Dare VX9700 Cell Phone
Picture ID with samsung U540
This might be a possible solution....as I have had the same problem, with 2 phones...
Finally, I went to another cell phone rep - and we FIXED the problem!
My cell phone numbers in my phonebook are all saved with "1-area code-phone number" ie: 1-555-555-5555. The problem came from when people were calling me, locally, their number would come in as are code-phone number ie: 555-555-5555. The cell phone couldn't match the caller ID perfectly, so it would alternate between blank pictures, black pictures, wrong pictures.
Re-save your numbers, without the 1, and it should work fine - well, it did on my phone! :) Good luck!
Jan 07, 2008 | Samsung SCH-u540 Cellular Phone
Samsung Instinct Cell Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
