Question about Frigidaire CWS3600AS Top Load Washer
I have a frigidaire washer, when drum spins it
I have a frigidaire washer, when drum spins it squeals. Help!
    President:
  • 1,124 Answers
It is probably the belt.. Replace the belt and that should take care of it..
Have a nice day..
Posted on Sep 08, 2009
Testimonial: "Thank you very much, I will try and replace belt."
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
FRIGIDAIRE LTF2140FS1 SPIN SLOWLY
Hello friend, thanks for your post!
I understand that the spin feature on your Frigidaire washer is spinning slowly. It sounds like a potential problem with your motor control board or control board. I would recommend performing a reset and you can do that by disconnecting the power from your washer for roughly ten minutes. If that does not help correct the issue I would recommend having a professional come out. They will be able to pinpoint the cause of the issue and replace any electrical components to avoid any personal injury or future issues with your washer. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
Troubleshooting kenmore washer front loader 417 390 12890
basket rubbing to the door gasket ..could be bad bearing or broken spider
Mar 01, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My fws1339a frigidaire top load washer squeals at end of spin cycle. help
Hi teribrad, thank you for your post!
From what you have described, it sounds like you either have a problem with the belt, front (and/or rear) bearing, or a loose connection with the motor or drum. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replaced depending if they are worn, damaged or loose. You can often locate a qualified tech through the manufacturer website.
Jan 10, 2014 | Frigidaire FWS1339A Top Load Washer
My frigidaire combo unit the dryer is squealing?
the felt that rounds the drum that touches the front panel could also be worn and you can have a situation where metal is rubbing
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
Dryer squeals off on during the cycle
The rear drum support must be replaced.
Part number 5303281153
Nov 29, 2008 | Frigidaire GLGH1642DS Front Load Stacked...
Squealing noise
possible causes are:
bra wire stuck in tub and rubs against the drum and squeals when on spin.
lip seal at front of bearings squealing - this is a difficult repair
Sep 02, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire CWS3600AS Top Load Washer Logo
423 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
