Question about Canon imageCLASS D880 All-In-One Laser Printer
Image class 780 ADF jamming problem
Image Class 780 ADF will not feed properly, it jams up after the first page goes through or sometimes wont even let the first page go through.
  • 108 Answers
The problem could be with the ADF rollers. First open the top ADF cover and clean the rollers gently with some isopropyl alcohol on a soft cloth, let dry for about 10 minutes. Also check to see that the top seperator pad is not worn out. This pad should be cleaned as well. If this does not work the ADF rollers and the seperator pad will have to be replaced.
Posted on Sep 08, 2009
ADF will not feed
Canon Image class does not feed.
Dec 29, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
My canon image class says I have a paper jam, but I removed all the paper. I hear something that sounds like it's trying to pick up the paper from the paper tray but it doesn't pick it up. Help!
try to clean the feed rolls with the help of wet cloth.it will solve t he problem.once u have taken a page out.take 10 to 15 more to clean them better
Jun 29, 2011 | Canon Office Equipment & Supplies
D1120 IMAGE CLASS CONTINUOUS PAPER JAMS ALTHOUGH NO PAER ACTUALLY JAMMED. APPEARS THAT PAPPER IN PAPER TRAY IS NOT FEEDING OR CATCHING UP TO BE COPIED.
first of all try to clean trays picked up rollers and also look for a piece op paper or something else in internal paper path
pifonski
Feb 20, 2011 | Canon imageCLASS D1120 Copier
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
Document jams in the ADF (Document Tray)
  1. Press <Stop/Reset>.
  2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
  6. Close the Feeder Cover.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    When rescanning the document after clearing the error, rescan it from the first page.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
  3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
  4. Open the Document Cover and pull out the document from the inner side.
  5. Close the Document Cover.
    Note: When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Canon image class 6550 adf area document to long error
You orginal feed rollers may be worn out. when this happens, the paper slips and the machine thinks the paper is too long.
You need to have the ADF rollers replaced.
Jul 06, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon imageCLASS D880 All-In-One Laser Printer Logo
259 people viewed this question
old marine
old marine
