I have a Kenmore Elite HE3 front loader washer. I
I have a Kenmore Elite HE3 front loader washer. I keep getting the f 02 code. It won't spin and drain the water at the end of the cycle and now I can't get the laundry out. We've disconnected and cleaned every hose right up to the drum and there is no clog. Is there an additional trap somewhere?
  • 5,911 Answers
"F02" is a Long Drain error. The error code is generated when the drain time exceeds 8 minutes. In most cases this means you need to clean out the trap on the drain pump. The following link explains the error and how you need to remedy the problem. There is a follow-on link included that explains how to access the drain pump and clean it: http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore If the error code reappears after you clean out the drain pump, you may need to replace the pump. If the pump motor or impeller is damaged and it is not pumping at the correct volume, the error code will continue until the pump is replaced.
A replacement pump (if needed) can be purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever part source you like, but I have found these sites to be the most reliable and offer competitive pricing.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Posted on Sep 08, 2009
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
    either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
    Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE3 front loader F-11 and FDL codes
    yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
    Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
    Check Pump on front loader kenmore HE3 elite
    Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
    May 26, 2009 | Kenmore Elite 45986 Front Load Washer
    Help! Mt Kenmore Elite Quietpak2 HE3 keeps
    F/06 Drive Motor Tachometer Error
    The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
    • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
    • Check the Drive Motor
    • Check the MCU
    • Check the Wire Harness
    Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Washer won't spin- flashing "f 02"
    in the HE3 series it means the drain tube or pump is clogged
    Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Front loader washer doesn't spin clothes as dry as before
    The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
    Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore front loader washer HE3 kenmore Elite
    ok " there is a filter on that line ,it has to be cleaned
    to locate filter, follow hose back to filter
    filter will come apart for cleaning
    Jan 11, 2008 | Kenmore 44832 Front Load Washer
    Kenmore Elite HE3 washer keeps filling with water
    The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
    Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    189 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
