Question about Apple Computers & Internet
Thotsa I shut down last night normally but today nothing. I press the powerbutton, The hard drive makes the two little sounds it always makes butno orchestra start up sound and the drive doesn't seem to startspinning either. tried starting up with command+option+p+r to clear the memoryand nothing works. I'm going to take it in on Monday but I have work todo so if anyone can suggest a do it yourself idea, I would reallyappreciate it. Thank you.
  • Apple Expert
  • 481 Answers
If you have cleared the PRAM with command-option-P-R and you do not get either a chime or error tones on boot, you have a logic board or power supply issue, and there is no DIY fix for this.
Posted on Sep 19, 2009
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Dec 23, 2010 | Dell Dimension E510 PC Desktop
My mac book wont start up.
this is classic, leave it without battery and power for few days and see what happens
Mar 20, 2009 | Computers & Internet
Does not recognize
Did you try the disk on a different computer to make sure the disk is functioning?
And if using a laptop, make sure that power is not an issue, an external power supply or 2 USB ports are always required.
Also check:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Maybe one of those troubleshooting suggestions can help you.
Jules
Mar 16, 2009 | Western Digital External USB 2.0 80 GB...
Gateway 7330GZ wont boot
for me this is the try and test situation,
try to remove ram -- look what happen. or try to turn on the laptop with the xp cd in the drive rom, there a similar case and the problem solved after i take out the keyboard and put it on again.
Jan 18, 2009 | Gateway 7330GZ Notebook
HP wont turn on
HI SOUNDS LIKE THE POWER SUPPLY'S HAD IT WHY DON'T YOU ADD THE HARD DRIVE TO YOUR NEW PC AND COPY EVERYTHING OVER
Jan 03, 2009 | HP Computers & Internet
Trouble starting compaq presario F551AU
Hey I apoligise for the late reply,
Ok, first off when you turn off the computer without shutting down, windws does not get enough time to wirte necessary data to the disc, this does not always cause aproblem because sometimes there are unpredictable events such as power failure..
You might need to format your hardrive to fix this problem
To do this boot with the windows cd, it will say press any key to boot from disc. (YOU MIGHT NEED TO SET YOUR BOOT DEVICE IN THE BIOS(SETUP))
anyway fisrt off try a fresh install, leaving your current file system intact. Id that works then you will still have all your data on your disc, If not then you need to do a complete format.. Good Luck
Dec 29, 2007 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
WD - My Book Won't shut off with computer, and now can't locate
Try unplugging Hard Drive, then a reboot of your pc and when the pc comes back plug it and then Power it ON. Hope this Helps Mutahir
Feb 03, 2007 | Western Digital My Book (WDG1U2500)...
Computers & Internet Logo
59 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
