Question about LG 42LC2D 42 in. LCD HDTV
Sound Just moved and had new cable installed...first couple of days sound was good..kept it around 15 or 20, now can turn it all the way up to 100 and hardly any change...
    Novelist:
  • 148 Answers
Cable box has its own sound level control, most likely. use its remote to adjust that.
if that is what you are adjusting, then you need to next adjust up the volume on your sound producing device(s) such as your amp or your tv
good luck
mark
Posted on Dec 23, 2007
My chrome cast screen is stuck showing the 100% sign with a circle moving around it
Sounds like it got stuck doing an update. Cycle the power on the chromecast. Unplug the chromecast and re plug it in.
Mar 09, 2014 | Google Chromecast
Moving house
All depends on how far the homes are from each other. But average cost is about $100.00. That's hoping that electrical and plumbing are correct for your equipment.
Jun 30, 2013 | Zanussi Washing Machines
My a/c compressor in my car messed up so i took it to get it fixed i put the oil and freon in a couple days later but the day after i got my car the steering wheel started shaking then it stopped and it...
Do you hear a sqeal like a belt ????? It sounds like your air compressor is trying to lock up.....In turn would make your belt slip and power steering act different....
Nov 18, 2011 | 2002 Ford Taurus
Battery is 100% charged but when i unplug the cable the computer goes off. Why?
The batterycould be old.
lithium batteries does not go dead when old
You simply cannot get the energy it stores.
That isthe draw back with them.
Other wise they would probably last forever.
Jan 20, 2010 | HP Compaq 6510b PC Notebook
I cant find where my ford mustang 3.8l v6 engine is grounded?
Check the starter cables, check the earth cable should be around the gearbox to chassis or anywhere around the engine to chassis.
Does the igintion come 'on' and indicates at the dash panel?
Nov 28, 2009 | 1995 Ford Mustang
When I turn on my HP dv9000 I get a constant loud beep. have to hit escape button to stop it several times
Re: dv2000/dv6000/dv9000 recall ubatz - Just got my laptop back from repairs a couple of days early. Cosmetically it's perfectly fine.
I kept the easy peel plastic on the lid, had an extra one and covered all around inside the keyboard (but not the keyboard itself). Got a page that says the LCD cable was fixed.
The rubber circles at the bottom of the LCD panel are pushed in at an odd angle but I'm afraid if I try to move them back, they're going to pop backward and disappear altogether behind the LCD.
I did order my Vostro last night and changed my sig file a few minutes ago to remove the DV9700T from it.
I haven't turned it on yet. Mixed emotions. Ah well.
Oct 21, 2009 | HP Pavilion dv9000z Notebook
95 camry speedo meter and odo meter stops working all of a sudden again it starts working. Some days the check engine light glows with odometer off light and after couple of days it works fine Please help...
It sounds like the Speedo cable is going bad remove the cable connector on the side of the transmission and twist the cable and see if the odometer moves, you can also pull out the cable from this end and check the Speedo end, if it's bad it will be rounded off rather than square. If the gear in the transmission is bad you can put the cable into the end of the Speedo gear on the transmission and try turning it if it turns around say a half turn or more then the gear is bad, all you do is pull out the bolt and the small horse shoe clamp and wiggle out the gear and go buy a new one at the dealer or transmission shop, if the cable is bad you can buy a cable kit for $12.00 the gear is about $10.00. The check engine light would come on because the Speedo is malfunctioning and uses the info from the Speedo to input injector pulse width.
Jun 24, 2009 | 1995 Nissan Pickup
My camera won't turn on
I had exactly the same problem with mine. Here is what I did to fix it.
put new battery in
1- Clean around the lense
2- While turning the camera off, press the lense in (up and down with lense movement) NOT too hard. Try that a few times until the lense either retract 100% or almost 100%. If almost 100%, press on the lense a little harder so that the lense be in 100% (like it normally closes)
If you turn your camera on and off a couple of times, your camera will work as it does normally.
GOOD LUCK!!!!!!!!!!
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Air nailer won't nail
If youve never done anything to it could be a couple things. Have you kept it oiled (about 6-8 drops) before using and again at lunch if construction type work. Check the nails to make sure they move freely in the magazine Check the nail guage for proper size. and what I would do is fire it till it skips disconnect the air from tool and open the front door (for removing jams) and see the driver position. If it is partially down that would be the problem, check the driver for being bent. Lastly remove all nails and just tap the nose on a piece of wood and again check the driver position, if it moves or falls freely then the tool would have to have new rubber which might be a good idea anyway. Get back to me with the model number and I will research and see if they make an o ring kit.
Jan 20, 2009 | Porter Cable Cable No. FC350A Clipped Head...
Denon 1508- no sound but smoke.
perhaps u might consider going to a(n) (unauthorised) repair centre. just check with folks around u or maybe audio forums within your area. authorised agent doesn't always mean the best. i suspect they may have used reconditioned components.
Aug 31, 2008 | Denon AVR-1508 Receiver
LG 42LC2D 42 in. LCD HDTV Logo
67 people viewed this question
