Question about Health & Beauty
I have a chefmate nutritional scale that was working fine,then all of a sudden the screen started saying out2. replaced batteries but nothing so far.
It is not OUT2, but rather OUE2, which means your chefmate needs to re calibrate. To do that you will need the following:
a 2000 grams weight or 4.4 lbs, I used a 3lbs protein jug unopenened and a 600 grams glutamine bottle unopened.
Ok so turn your scale off then:
1) press the ON button and leave it press while simultaneously pressing once the TARE button (though it may need more than one or maybe leaving it press for a few secs thought try just hitting it once first), release the TARE and you should see a CAL on the screen (top left), release the ON and it will read:
2) the number 00000 on the first line will appear, click TARE
-this calibrates no weight first-
3) then it will read you another weight mine read 2000 grams, put that weight on top of the scale (NOTE every scale uses a different weight to calibrate i am giving you mine) once you put it there hit tare and it should read PASS
4) Remove the weight and it should read "0", mine read first 1 grm so i had to re do it again until i got 0.
5) You can try weighting different unopened things that you know the weight of, but if not just turn it OFF then back ON and it should read "0"
Congratulations your scale is now calibrated and ready to use again!!!!
NOTES: i have the electric scale if the on tare button does not works for you it may need a different combination to calibrate.
Posted on Oct 22, 2009
Thank you for that good description. It worked. I took a 2 liter bottle of coca cola zero, poured out half a deciliter to compensate for approx 50 gr plastic bottle...(without the cap on) and then followed your instructions. And now i have a good scale again, and have saved a lot of money.
Posted on Apr 10, 2013
I need a free user manual for a chefmate digital scale. Where could I find one?
https://www.tradebit.com/filedetail.php/140213290-chefmate-digital-nutritional-scale-user-manual-food
Dec 31, 2014 | Health & Beauty
My digital gram scale does not work. the screen has some kind of word. Please help
Try recalibrating it by turning it on while holding the "tare" or "mode" button. It should show a raw data from the sensor then. Press the tare button again and it should calibrate the empty weight. Then it will show a specific weight you should put on, usually 100g. It should automatically finish calibration now. Hope this helps. The words before calibration on my scale was OUt2
Sep 24, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My ProScale XX 250 shows out2
I had this problem with my Silvercrest kitchen scales model z30170. Being wall mounted the weighing platform was on a fold-down flap . It turned out to be a broken wire in the hinge joint.
Dec 28, 2012 | Tanita 1479V - Digital Pocket Scale /...
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
Why dose my proscale orion 150 pocket scale say out2 when I turn it on, and will not change to 0.00?
It's possible that the tray is pushed into max position.
Incurred due to an overload on the tray for a long time or a unprotected transport probably ...
Try turning it on, while holding the tray pulled up (eg scissors sliding under the tray to keep it elevated) and if the scale will show you "0.00", the tray is pressed...
Jul 27, 2010 | Tanita 1479V - Digital Pocket Scale /...
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
How do you switch Chefmate digital scale from grams to ounces?
toggle so that "weight" is blinking, then hit zero or "0". that's it.
Jan 30, 2010 | Chefmate Kitchen Appliances - Others
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
Need manual for the Chefmate Digital Nutritional Scale
Redtruckie,
The contact information from my manual is:
e-mail: sales@alldmd.com
Phone: 314-453-1606
Customer support: www.weighoflifescale.com
Hope this helps.
Bill
Mar 17, 2009 | Health & Beauty
Health & Beauty Logo
1,526 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
