I need instructions on how to clean the lens on a Panasonic DVD Recorder Model # DMR-EZ17. he manual says to use the DVD lens cleaner. We bought the unit two years ago and I don't know what the lens cleaner is or where to find the lens for that matter. Is the cleaner a soft cloth or a chemical? When playing a disc, the picture is extremely dark. Too dark to watch. Thanks for your help. Pat Robinson
    President:
  • 1,187 Answers
Radio Shack ($13)
The lens cleaner is a CD "Audio" disc that has some imbedded brushes on one of the audio tracks.
Read the instructions carefully (no harm if it's not done right). Turn ON your speakers or listen to the CD/Cleaner through your headphones. There are no chemicals involved, and can be used several times.
The problem (darkness) may not go away.
It seems more like the voltage level on the DVD output or the TV input is too low.
If you have several things connected to the DVD, disconnect them, except the TV.
If you have other devices turned on that are connected to the TV, turn them OFF (like a VCR or another DVD player, etc).
Please "comment" back...
Hope this helps!
Posted on Sep 08, 2009
Testimonial: "Thanks for the quick response! I will try your suggestions. Pat"
NO DISC message whether there is a disc or not
Clean your DVD Player if not and then check the wirings of the main system
Oct 02, 2012 | Panasonic DMR-EZ17 DVD Recorder
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
My Panasonic DMR-EZ17 DVD Recorder keeps saying
You have to use the remote for this unit or a remote for a similar dvd recorder, when you have it hold the enter/ok button and the number 1 or which ever number your stuck on 2 or 3 for 5 second and then go into setup and change it to the one you want RC1 ,2 or 3 !
Jun 26, 2010 | Panasonic DMR-EZ17 DVD Recorder
My panasonic model dmr-es20deb will not read discs
Clean the Disc Lens with a good Lens Cleaner !
Feb 17, 2010 | Panasonic DMRES15 DVD Recorder
Read failure o DVDs on Panasonic DMR-EX75
You need a lens cleaner to clean the lens of ur DVD recorder..
Dec 09, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DMR-EH55 DVD recorder is not able to read DVDs any more
You purchase a dry DVD lens cleaner and put it inside the tray. It will clean it for you. If you take apart the drive to expose the lens, you are actually at risk of making it worse.
Mar 08, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Fuzzy Picture
Are you using the component (RGB) outputs, and a Sony TV? I believe that there is something in the output of at least some Panny DVD recorders (over the RGB component path), which Sony TVs don't process properly.
Aug 15, 2007 | Panasonic DMR-EZ17 DVD Recorder
No picture
[I am assuming that the recorded disc was not made using the DVD recorder]. It's most likely that the video portion of the file is encoded in a format that is not supported by the DVD recorder. The player only supports DivX, JPEG, and MP3 formats. So try transferring the file on the disc to a computer and encoding in a supported format. You can use free online services such as http://media-convert.com/ or http://www.zamzar.com/ to encode media files into different formats.
Jul 29, 2007 | Panasonic DMR-EZ17 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
