Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Unable to print 50 pops up and the system won't do anything, new cartridges and still nothing.
    President:
  • 2,306 Answers
That error is usually when the encoder strip comes out of the sensor on the carriage assembly. It is under the case toward the front of the machine, you can't see it without a mirror and flashlight. fingerprints and grease will stop it from reading as well. Best done in a shop, but good luck if you try it yourself.
Posted on Sep 08, 2009
MFC-665cw unable to print 50
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment.
hen you open the printer so that you can see the print head, move the print head with your hands, pull it to the middle. The space immediately to the front of the printer is blocked by the plastic shield. you can curl your fingers down under this shield. you will feel the encoder strip, which is about 8 mm wide, and is a plastic ribbon, or strip. It runs from left side to right side across the printer, in a vertical orientation. This is the encoder strip. Past this you can feel a longer rubber belt, which is about 3 mm wide. This is not the encoder strip, it is a belt and you don't need to be concerned with this.
Place your fingers on the encoder strip on either side of the print head, and flex it, bending it up and slightly back and then release it. Try this several times. Do this with power on. Once the encoder strip is back into it's slot the printer will start a cleaning cycle and start working.
Solution found here originally.
Oct 16, 2012 | Brother MFC-665CW All-In-One InkJet...
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to print code 50
put the right print cartridges in from Brother...brother
Aug 20, 2008 | Brother DCP 130C All-In-One InkJet Printer
i got a brother printer dcp135 ,but it got a error (print unable 51)
how i settle it???
thx...
May 29, 2008 | Brother DCP 130C All-In-One InkJet Printer
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
Unable to reset printer after installing new ink cartridges
I want to known you have replaced the cartridges or refill the cartridges.
Feb 23, 2008 | Office Equipment & Supplies
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
298 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
