Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
I have approx 1000 MC 9090-g Handhelds deployed in 250 buildings from coast to coast. Some area have extreme temps both in the summer and winter months. -20 to 115 degrees+. What options are there for the batteries in these units. Battery life is severely shortened in these environments.
One less costly solution would be to purchase Honeywell batteries. It has longer battery life than Symbol/Motorola. The other solution would be to purchase freezer units for the areas that need it the most. MC9090 has an operating temperature -4° to 122° F so you should be fine with the heat situation. Check out our site @ http://www.beefive.net.
Posted on Oct 20, 2009
How do I change sounds on 9090 scanner
Looked though the user manual, and it does not appear that is capability exists. Manual states that the unit will beep after a tag is read. No programming information was presented to change any sound options.
May 14, 2015 | Symbol MC 9090 (sym-mc9090gk0hbega2r)...
I have a Siemens KG..V fridge/freezer - seal
This heat is coming from the mullion heater that wraps around the opening of the freezer and refrigerator door openings. This heater is used to eliminate condensation forming around this area. If you have a moisture switch or summer/winter switch, set it to the off or winter position. This should turn the heater off.
Oct 20, 2014 | Refrigerators
What size coil fits this
The 70 stands for 70,000 btu and the 16 stands for 1600 cfm.. Air conditioning requires 400 cfm per ton, so the blower is capable of delivering enough air for a 4 ton a/c unit. However, the blower is is amultispeed and has a 'blower chart' in the manual that will give you an idea of air flow delivered on all 4 (usually) speeds. You wouldn't want to deliver 4 tons of air across a 3 ton coil. That would effect the temperature drop across the coil and also effect humidity removal.
4 tons of a/c is a considerable amount of cooling, so unless you have a large space or extremely high average summertime temps, I would ask a local contractor to do a heat load calculation to properly match a system to your specific needs.
Every area has a 'design temp' around which a system should be designed. Here in the St Louis area, the design temp for the winter is 5 degrees and for the summer its 95 degrees.
70,000 btu in gas equates to 20 kw in electric heat for what its worth.
Jun 15, 2014 | Comfortmaker G8MXN0701716A 66,000 BTU 80%...
Wondering what type of oil to use for winter between 5 - 7 degrees Celsius
The Virago uses 20W-50 oil in warm weather. If you ask any bike shop they will recommend moving to a 10W-40 in cold weather down to about 30ish F, and if you plan on riding down to extreme temps of about 20F and below, then a 5W-30 or 5W-40 is recommended. For the 5-7C temps you list, you could really just use the same oil you use for summer. Just take a little extra time in letting the bike warm up and don't ride it hard the first couple of miles to let the oil come up to full temp. If you prefer to err on the side of caution, then use the 10W-40 oil. I had a Yamaha 650 Classic and I used 20W-50 year round and never had issues as long as I made sure to warm it up properly first.
Nov 20, 2013 | 2005 Yamaha Virago 250
Symbol MC9090 I formatted the Symbol MC9090 installed the drive after I do a setup on the device everything works correctly, after rebooting the symbol mc 9090 its configuration is...
this is because you are cold booting the unit. Everytime you cold boot a 9090 it re-sets all saved settings. You need to warm boot only unless you want the unit reset to default. any problems please mail technical@codeo.co.uk for support - we supply MC9090's in refurbished condition complerte with like new warranty incase you need any
Oct 21, 2011 | Zebra Symbol Technologies MC909X-G Series...
How often do i need to replace my fuel filter?
SIMPLE MAINT SCHEDULE , IS CHANGING IT ONCE A YEAR, but it depends where you live, If this truck is a diesel & you live in a northern climate, change your filter once a year but not until you know for ceretain that you are buying winter grade fuel, ie: nov
Reason for this is that there will be wax/parafin build up in the filter that your ran on the summer fuel, it can congeal in the filter in winter becasue of this build up. If you replace the filter in late autumn, then tat filter will not have a congeal problem because the there hasnt been anything but winter grade fuel through it, , and its safe to run all next summer , but the summers residue will cause problems next winter , so change again in late autumn .
Sep 27, 2010 | 2001 Dodge Ram 2500 Truck
2000 Dodge Caravan 3000CC engine - In summer, temp gauge in the center. Water temp is 190 degrees. In the winter, temp gauge at quarter level. It takes forever to rise. If you use the heater, the temp in...
Sounds like a stuck thermostat. The thermostat cycles open and closed in order to maintain a temperature range, some cars with very sensitive gauges reflect this opening and closing, but most cars have gauges that are somewhat less responsive in order to keep people from thinking something is wrong. I would defineately replace the thermostat and flush the cooling system, replacing the fluid with fresh.
Dec 22, 2009 | 2000 Dodge Caravan
87 sr5 with 22re. runs hot i summer and dont in winter so i replaced water pump,thermostat, flushed radiator, checked timing and cant figure it out. Thought about head or head gasket but it should cause it...
It is your radiator. Too stopped up for a flush to do any good. Cooler temps in the winter will keep it cooling better versus hot summer temps.
Jun 15, 2009 | 1987 Toyota Pickup
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
374 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
