Question about Panasonic KX-TA62470-2 (KXTA624702) Expansion Module
Verizon zapped out kxta624 now outgoing lines not working properly
Hi, verizon came out to work on a line that was not working correctly. we lost all of our phones. i was able to reboot by turning the system off unplugging and then turning it back on. we have the 3 line expansion card. the first 3 lines still require dialing 9 to get out, but the second 3 do not. i set up speed dial at the phone so this does not work for the second three lines. i had a tech come out but he insisted this was the fault of the phone company. he reinitialized the phone box. verizon insisted this was a problem at the box. it is still not fixed and monday is coming quickly. is there anything i can do to get this working?
    Sergeant:
    Champion:
  • 298 Answers
This site has a forum you milght try
you could check the archives
Posted on Dec 09, 2007
I can't make any outgoing calls, although I do receive incoming calls, it keeps saying the phone number is wrong but I've dialed correctly plenty of times. What is wrong with my house phone?
Does it do with all outgoing numbers or just one?
Sounds like there is a fault with your line. There is a setting at the exchange that bars outgoing calls. Phone your service provider and ask them to check the line and the settings.
Jul 19, 2016 | Cell Phones
Tip
I cannot access my Verizon mail _ Verizon.net server responded: Authentication...
Hi.
The following tip applies to users that want to access Verizon mail using an e-mail managing software as for example Outlook, Outlook Express, Eudora and similar.
The checkup procedure and server settings can also be used to setup your verizon email on a mobile or on a PDA.
If the Verizon server responded: Authentication failed, that means that either your ID, or your password had not been recognized.
Ensure that Caps Lock is not on.
ID and password are case sensitive, ensure that you use capitals only if needed.
Ensure that you entered the right user ID and password for your mail.
The ID must be your Verizon email address, or the first part of the Verizon email address (before @ sign). Password must be your Verizon email password.
If for example the address is MyMail@verizon.net , then try first putting id MyMail@verizon.net , if that does not work, try again with MyMail as ID.
The format that is supposed to work on Verizon is MyMail@verizon.net.
Ensure that the server settings you are using are correct:
1. Incoming mail server (POP3) - incoming.verizon.net.
2. Outgoing mail server (SMTP) - outgoing.verizon.net.
Ensure that you have not set the Log on using Secure Password Authentication (SPA)
Ensure that ports are POP3 PORT: 110. SMTP PORT: 25
Turn off any active firewall or security software. Also ensure that your router is not blocking port 110 (for POP server) or port 25 (for SMTP).
If all that does not work, then there may be an issue that depends on Verizon server. Also try calling Verizon online to find out if there is any additional issue that can affect your account.
Regards.
on Mar 12, 2010 | Microsoft Office Outlook 2007 for PC
Hi..Caller ID function not working on our base and handset phones Model No. KX-TGA641. Used to, but now does not. Pls help! Thank u
I have a problem on a Panasonic two line handset phone that when one line is plugged into a VoIP line, it makes the caller ID not work for the other line. After going back and forth with Verizon, we finally figured this out. I haven't figured a workaround. And in my old house I used to have a VoIP line and a FiOS line and it worked. So either something has changed or the difference between FiOS and regular copper line from Verizon is making the difference. peter@phipower.com
Dec 30, 2010 | Panasonic Lands Phones
My all-in-one printer will not fax outgoing or pickup incoming facsimiles. Any ideas on how to resolve?
Assuming it's working properly, you might have a connection problem. Verify the telephone cable is plugged properly in the correct port on the printer, and that it *makes* the proper connection (it must be a two-conductor cable: only the central two pins of the four or six available in the clear plastic male RJ11 connector must sport the copper prongs). Verify that an external phone, connected to the L7580, and the L7580 to the wall socket, can pick up the line.
If these checks all pass, the only thing which comes to mind is line voltage.
Jan 03, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
1999 dodge diesel 3500 transfer pump runs properly but wont pump fuel even sticking line in jerry can
most pumps wont pump until they have been primed,some pumps do something called "cavitate" or another term is "vapor lock"so try cracking the out going line,priming the pump with a little fuel in the incoming line and then placing it into the external container.when you get fuel coming from the outgoing line then you can cinch up the outgoing fittings.
Oct 12, 2009 | 2004 Dodge Ram 2500
Intermittently lose internet connection with my Westell 7500 DSL Router. Power, E4 Port, Wireless and DSL LEDs stay on but the internet LED goes out. Verizon has replaced the router but the problem...
hi,
I used to work for verizon for two years as level 3 support,here is the thing,if verizon already replaced the modem,that means that its not really the modem,its the connection,thats what we call intermittent route,here is what you are going to do,contact verizon,have them run an intermittent connection line test,tell them that internet connection is not consistent,they will create an active ticket for you,it will be forwarded to the central office and the central office will run a different test,thats what we call a test assist...they will be able to verify if the problem is the line form the central office going to your house...
thanks and God Bless
Jun 24, 2009 | Westell Wirespeed VersaLink...
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
Mar 20, 2009 | Westell Wirespeed LiteLine 6100...
I just switched my internet Server from Comcast to Verizon.I was told that the dedicated line I was using for my fax would also service the new Verizon Server. The fax( 2820) recieves incoming fax's but...
Finally, I have the email that works with B800SE BROADBAND FAX. If you would like an email to test, please send me an email. One email is $12 only for one year.
Feb 23, 2009 | Brother Office Equipment & Supplies
Kxta624 problem with programming jack #01
I do not have any 824's in my network - I do know that on the 616 there is a set/program or run/program swith on the KSU that MUST be set to program before any work can be done on the first port
May 13, 2008 | Panasonic KX-TA62470-2 (KXTA624702)...
I've lost an outgoing line--inoperable
Have the same problem... whats the way out for this?
Apr 01, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TA62470-2 (KXTA624702) Expansion Module Logo
119 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
