Question about Akai PT4298HD Rear Projection Television
Lamp red light is on when tv is on and not flashing tv info says solid light is lamp life expired but tv is working fine is this a problem.
    Problem Solver:
  • 5 Answers
It's only a problem when you try and finance a new bulb ($400.00 for mine). But seriously, the only "problem" is that an older bulb exhibits much lower light levels and the picture has crappy color, brightness and contrast. Keep a coffe can around and put a few bucks in it everytime you watch it. when the bulb finally blows you'll have a couple hundred bucks in there towards a new one. (a little easier to handle)
Packman
Posted on Sep 08, 2009
Lamp light blinks 5 times
The lamp might be at the end of its life. Change the lamp.
Dec 19, 2012 | LG RU-44SZ61D 44" TV
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
I have a Sony Grand WEGA KDF-50WE655 50-Inch LCD Projection TV and when I turn it on the screen stays black and the green light flashes for 20-30sec then the TV turns itself off and 2 red solid lights...
The tv projection Lamp inside the tv now has it been inside this tv like 1 1/2 or 2 years already and tv is on and used it like 4 or 5 hours every days?Yes,the tv now the 2 red LEDS solid lights apear.One of those light have a word "Lamp" written on it bazel frame?Yes,100% ur tv projection Lamp life are over and ending.Tries websites like Ebay.com,Partstore.com to buy a new tv projection Lamp for the replacement.
Jul 18, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
We use NEC MT1065 and just replace its lamp but it still won't switched on (lamp indicator led is red). How can I reset it ?
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, if your old lamp has only had the reflector replaced then it will make no differance because the chip tells the projector weather or not to power up depending on the hours its counted, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention, just as an added note, a solid red lamp indicator light means that the lamp has expired, if its flashing red this means its nearing the end of its life, if the status indicator light is flashing then there could be another issue, by counting the flashes you can reffer to the manual in the troubleshooting section to diagnose the fault, I know this is very late, but anyone else reading this may find it helpfull.
Nov 29, 2010 | NEC MultiSync MT1065 Multimedia Projector
Four blinking lights from standby led lamp after I turned on the TV.
Yeah, it is not lamp problem. Check fans in tv as one of fan is stopped for some reason and causing problem.
Jun 29, 2010 | Sony KDS-R50XBR1 50" HDTV
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Akai PT4298HD Rear Projection Television Logo
150 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
