Question about Garmin Gsd 21 Sounder Blackbox Fishfinder Module
GPSMAP 478 and GSD 21 connection issue
I have had these units conneted for about 3 years with no issues. Now the transducer is not communicating with the GPS478 unit. it is indicating that there is a wiring issue. after substantial checking and rechecking of the wiring and fuses, I am lost........ can anyone help?
2 Suggested Answers
  • 64 Answers
SOURCE: could you please let me know witch transducer to
Here are your options:
In-hull Mount Transducer (200/50 kHz, 12/45 deg)
010-10327-00
Thru-hull Mount Transducer with Depth and Temperature
010-10194-01
Bronze, Thru-hull Mount Transducer with Depth and Temperature
010-10182-01
Transom Mount with Depth, Temperature and Speed
010-10192-01
Transom Mount with Depth and Temperature (200/50 kHz, 10/40 deg)
010-10272-00
Thru-hull Mount Transducer with Depth (200 kHz, 12 deg)
010-10107-00
It all depends on the type of boat and how you are going to be using the fishfinder. Here is my email: kevin@sun-me.net if you want to discuss your uses further and if you want to purchase a transducer.
Posted on Jun 14, 2010
Testimonial: "thank very much for info it was spoton"
Garmin 100 echo stays in simulate mode. Is there a setting to change it to live mode?
1 turn off the simulator in the menu.
if that does not work
2. Check the connection to the transducer, if it is unhooked or corroded, clean and reattach the connector, the unit will stay in simulator mode if it does not detect a transducer attached to it
Apr 21, 2014 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Garmin 541s transucer, unit problems
Sound like the transducer is catching air.
May 10, 2013 | Garmin GPSMAP 541s
My GSD 21 is mated to a Garmin 3210. Bought both componants new. Every single year since new it works 2-3 trips. Then just doesn't come on. Have to send it back to garmin who so far have waranted...
The GSD 22 is discontinued. I would not buy any electronics that are discontinued, because there has to be a reason.
If I were in your shoes I would be looking a full change to either the brand leaders, Raymarine or Humminbird. I have had Humminbird since 2007 with a 798SI and since 2014 with a 998SI HD. 100% reliable for GPS and depth. Boat used twice a week May to October. The 998 has features to set a chart course and I do that when coming from Toronto to Port Credit. Humminbird also do full chart plotters, but in Georgian Bay, I wouldn't have thought necessary unless you use an auto-pilot. Uses Blue Chart maps.
You aren't the only one to have problems. Read the link below.
I did find this thought and there are others in the thread
http://www.thehulltruth.com/marine-electronics-forum/146766-installer-i-stumped-garmin-problem.html
Make certain that the transducer(s) cable is separated from any engine power cables. When those wires cross or are bundled together, the highly sensitive sonar signal gets polluted with high amp noise bleeding off the engine wires, and you're lucky to get any signal.
To test if this is the problem, shut your engines off and see if you get a good sonar view. Then start the engines and see if the same sonar quality is displayed. If it degrades, you've got the current bleeding problem.
I had this problem when I installed the new gear (Furuno 585, Airmar b60) and ended up re-routing the transducer cable using some "wire hangers" to keep the transducer cable away from the others. Now I get a firm fix on the bottom at all speeds and the only time the display gets lost is when I reverse the starboard engine, from air bubbles under the thru-hull.
GSD 21 with 3210 problems - Google Search
Mar 21, 2017 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Garmin 178c turns off on it's own.
Hi
Sounds very much like the wiring plug connections in the back, always overlooked but so important that connections are tight and contacting.
Jul 06, 2009 | Garmin GPSMAP 178C GPS Receiver
Garmin 178C Stays on for 20 secs then turns off
I had the same problem. In your settings you can set this thing to monitor your battery's power so it auto shut down if your battery goes below 11.2 volts or so. I disabled this and it has worked ever since.
Jun 16, 2009 | Garmin GPSMAP 178C Sounder GPS Receiver
Unable to track the bottom
I think you need to level the transducer. You have it pointed way out in front of you so that when you're going fast it is able to bounce the signal off the bottom and it comes back to where the boat has traveled to. When you're going slow you're bouncing it out in front of you but it comes back up in front of you. Sorry but I can't find a picture of a Garmin transducer. Hope this helps.
Jun 02, 2009 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Mar 29, 2009 | Lowrance X135 Power Pro Sonar Without...
Sounder not working
Interference like that is usually caused by electrical noise. Does it happen when everything else on the boat is turned off? If the answer is no, then you can isolate the source of the interference by turning things on one at time. Follow your transducer cable and make sure it has not been damaged or altered in any way.
Also make sure that your gain is set to auto
The GSD 21 has an LED indicator light on it. If it detects a malfunction the LED will flash in distinct colors or patterns. In the troubleshooting section of the owners manual there is a list that explains what each flash pattern means.
Jul 24, 2008 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Transducer
I have the exact same problem. Were you able to solve your problem???
May 12, 2008 | Garmin GPSMAP 3210 GPS Receiver
Garmin Gsd 21 Sounder Blackbox Fishfinder Module Logo
131 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
