Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Troy-Bilt TB425CS trimmer hard to start, won't accelerate
Engine spits through carb when trying to start it, acting like timing may be off. Is flywheel keyed on to shaft or is it screwed on? I have already installed new carb, new spark plug, new fuel lines and filter and fresh fuel. When the engine finally starts, it will not turn up rpm, and still spits when running near idle. Good spark, and looks like coil gap is about right.
Thought flywheel might have moved slightly if a key sheard or if it moved on threaded shaft. Any ideas appreciated.
  • 155 Answers
Hi the key is moulded as part of the flywheel on most machines these days which doesent take much to sheer off , By the sounds of it this may well be your problem.
Posted on Sep 08, 2009
When I compress the trigger to get higher speed, it dies on me.
Fuel jet may be plugged Not uncomon on small carbs. I had same problem replaced carb $19 from troy Built Problem solved
Jul 02, 2014 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Engine willnot start
Try taking out the spark plug,see if its wet,is the primer bulb ok?does the bulb fill with petrol when you press it,if this is ok,check the carb for dirt,and or the tank,is your petrol mix correct,as this makes a big difference to the run ning of the machine,rgds
Sep 26, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Im rebuilding carb on TB425CS and not sure I put everything in the way it should be is there a diagram I can look at
Plug your model number into the left hand side menu on this page:
MTD/Troy Bilt Replacement Parts
On the parts listing pages that follow, click on the magnifying glass icon to see an exploded, call-out diagram that will give you the details you need. Good luck!
Apr 19, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Starts and then shut off Troy bilt edger
clean out carb and run gas cleaner throught the tank
Dec 27, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I am able to crank the trimmer but it does not stay on. in the past it worked just fine but sat unused for roughly 4 months and now this. we own a TB425cs string trimmer. how do i fix this issue?
1) Change out the old fuel (not just adding fresh but pouring out the old and replacing it entirely) and check the engine oil.
2) Check muffler and/or spark arrestor screen for restrictions.
3) Clean and reinstall spark plug (check gap).
4) Replace inlet screen INSIDE the carb. (It is located directly under the inlet needle.)
Try each of these as needed.
Hope this helps!
Oct 01, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Sep 17, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt 4CC Trimmer - starts fine but won't turn off - TB425CS
Try cleaning up the switch button with Electronics Spray - you can get it from Wal-Mart for $3.
Usually is a bad contact or could be a broken wire .
Apr 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
1,019 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
