Tv on off switch not working - Televison & Video
  • 38 Answers
Most likely, it is not the on and off switch. Most likely, you are having problems in the power supply circuit of the t.v. It can be a blown fuse, but most the time something internally causes the fuse to blow like a output transistor. or a shorted diode. I hope this helps. don't forget to rate me if I was any help to you. Ron
Posted on Sep 09, 2009
TV on and off button will not turn TV on
Posted on Jul 18, 2010
TV box is not working wend Is connected to HDMI switch.
CONNECT IT AGAIN TO HDMI INPUT AND CHANGE SOURCE ON THE TV SETTINGS INPUT SHOULD BE HDMI1
Jan 31, 2014 | AUVIO 4-In/1-Out HDMI Selector Switch with...
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
Samsung LCD TV backlight switched off
if your TV is LCD or LED you have a faulty inverter board just replace it and your TV works fine again..
If plasma you have faulty y-sustain.
Hope it helps,,don't forget to rate and write a testimonial
Oct 28, 2012 | Televison & Video
My panasonic tv wont turn on and led light flashes twice
Our Sony TV sometimes won't come on when the switch on the tv is pressed. Weirdly, if we switch it off at the wall socket, wait a few seconds, then switch it on at the wall socket again, the tv switch then works......
Don't understand why this works, but if it gives you a work-around, it would be a lot cheaper than a TV engineer's visit....
Feb 20, 2012 | Televison & Video
I have a AL2671w LCD Acer TV ON OFF switching
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
Dec 05, 2009 | Acer Televison & Video
TV will not switch on from stand-by mode
keep pressing the channel up button and switch on the tv( plug it to the power). then release the channel button and press power on.
it should work.
Mar 29, 2009 | Panasonic Televison & Video
I have a Sony trinitron tv model no. KD32DX40U. When trying to turn tv on the red light below the on/off switch continues to flash red twice and green once when trying to switch on. Because of this tv does...
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. if this did not work then check with other power supply unit ....
Good luck..
Aug 01, 2008 | Televison & Video
ON/OFF
turning off mute with no remote on a rca reciever
Dec 23, 2007 | Televison & Video
Televison & Video Logo
798 people viewed this question
Top Televison & Video Experts
Electro Med Services...
