Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Jandy RS Light dimming relay replacement failure
I had a friend (HVAC contractor) install the replacement relay (after my pool company wanted $350 to do it). I saved about $150 by buying the part on-line. Once installed, it worked fine the first time but failed thereafter. We thought the part was defective, it was replaced and again, the same result after installation. Can you tell me if there's a common installation error that can be easily corrected?
    President:
  • 1,714 Answers
Two things come to mind. Check the 'coil voltage rating' on the relay and make sure that's the voltage that you are powering the relay with.
Nest question is the 'relay contact rating'. The contacts have a current rating that needs to be checked. If the load that the relay feeds is pulling too mcuh amperage through the relay contacts, they will fail. The rating is on the relay, must check both of these things.
Posted on Sep 08, 2009
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
I have a Jandy Aqualink RS OneTouch Wired Control Panel. The units light is on but there is no LED display. The unit continues to operate and turn the pool pump on and off at the scheduled times,...
It sounds like the unit itself may be out. The acid test would to be to get hold of a new one and switch them out. See if you can find a local pool company to work on that for you.
Dec 26, 2012 | Jandy AquaLink RS OneTouch Wired White...
Connecting problems
Installation
The scripts communicate with the Jandy system through a USB Serial Adaptor (e.g. the Keyspan USA-19HS USB Serial Adapter) connected to the Jandy Aqualink RS Serial Adaptor.
In order to use these scripts with SerialX, you will need to separately download and install SerialX as a Scripting Addition. As currently written, you will also need to determine the exact name of your serial connection and edit the following statement in both scripts:
property SerialConnectionName : "/dev/cu.USA19H47P1.1" -- Replace "dev/cu.USA19H47P1.1" with the name of your USB Serial Adaptor.
After editing, drag the Jandy Aqualink attachment script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Attachments
and the Jandy Aqualink background sync script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Background Tasks
Initiating use of the background script is typically accomplished by establishing a Trigger Action that activates on Indigo Server restart.
Usage
Assumes a Jandy Aqualink RS-4 or RS-8 Pool/Spa combination with auxiliary 1 set for pool light and auxiliary 2 set for spa light.
Unlike the previous version, the background script will now automatically execute periodically after being initiated (typically with a Trigger Action that activates on Indigo startup), will create variables as needed, and will update the status of those variables. By default the updates occur every 30 sec for most items using a single "#LEDS?" command, and every 30 min for the temperatures, with error detection if something does not update correctly. If the Spa is heating, temperature updates default to every 2 min. Variables created include AirTemp, ErrorFree, NextTempUpdate, PoolHeatEna, PoolHeatOn, PoolLightOn, PoolPumpOn, PoolSetPoint, PoolStateOn, PoolTemp, SpaHeatEna, SpaHeatOn, SpaLightOn, SpaSetPoint, SpaStateOn, SpaTemp.
Nov 22, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
How to wire the Aux 1,2 & 3 relays for Blower, spa light and pool light.
which ever you have wired to each relay connect the correct relay red and black connector then go to system setup and assign the aux and name them
Oct 24, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have a Jandy Aqualink RS8 Wireless One Touch system that is not operating right. Auxiliary 3 is not working at all. Each time the filter pump automatically begins, three other auxiliaries (5, 6 and 7)...
Yes, you can just replace the board.
There are internal signals generated by the cpu board that open and close your aux relays.
With this type of failure (multiple aux's tripping at same) it is always just a board problem.
You will want to recheck all the wiring before installing new board to ensure that a short is not being created due to a bad connection.
Oct 29, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have an Aqualink by Jandy RS8 pool control system. The system seems to no longer be able to control the heater from the inside panel. By reinstalling a jumper in the heater we can control it outside. I...
This may be the temp sensor or "thermistor" on the heater or on the Aqualink. If you have a book not hard to replace.
Check with your local BBB or Regestra of Contractors. Also look for pool orgnazations like NSPI (National Swimming Pool Instute) or a local servicemans orgnazation. Or call Jandy or go on the web to get their local rep.
Jun 24, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
In auto mode pool light goes on when ever it wants to
Is auto mode controled by a photocell? If so cover and uncover it to see if it reacts consistently.
Apr 30, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
280 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
