Question about True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F
I have a True Freezer, the compressor comes on but the fans inside the box do not so there is no cold. I replaced both capacitors but still no luck.
  • True Master
  • 1,147 Answers
Http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
Go to this web site and look in the manual on page 15. Check "Compressor runs but will not refrigerate". Gives some suggestions.
Now, inside the evap, usually strapped or clipped to the coil "U" turn on the end of the coil, is a Klixon device. This device comes in many different configurations. There may be 1 or 2 of these. One is a defrost termination switch. When evap gets hot enough so no frost is present, it terminates the defrost cycle. The other is a fan delay. It comes on when the coil temp gets to about 20 degrees. This prevents circulating warm air from defrost cycle. Now if there is only one device, it can be 2 in 1. That is, a defrost terminator/ fan delay. Will most likely have 3 wires going to it where as the 2 separate ones will only have 2 wires to each one. Now, either this fan delay is not working correctly or the coil is not getting cold enough. When it gets cold enough, it turns on the evap fans. This is most likely where your problem lays. Check it out.
Posted on Sep 11, 2009
Fan is not running in my True T49F Freezer
There is a switch above the door; check you have power from it when closed, then check the evaporator is cold enough as there is a thermistor that stops the fan until it is beginning to freeze. Lastly check the fan blade isn't stuck and the motor is ok.
Jul 02, 2012 | Freezers
How To Replace Relay On True T-72 Reachin
If it's mounted inside a box along with the capacitors there is 1 screw holding it from the back. Often you have to unmount the box from the compressor to access the screw.
Apr 04, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Compressor runs bypassed thermostat with wire that turns on and off compressor,but freezer cabinet is not cold 65 degrees evaporator fan does not turn on,condensor fan on,sttill no cold
If you have just turned it on it takes awhile for the fans to come on. The evaporator coil has to get cold about (10 to 20 degrees) and make a klixion fan switch to turn the fans ON.... Is the evaporator coils getting a frost pattern on them??? If not then the system may be low of Freon.. If the coil is completely froze up and you are getting frost back to the compressor..... then you have a bad fan switch or a door switch.... If you have a wiring diagram you can trace out the wiring.... It is usually down by the compressor or control panel... hope this helps.
Mar 30, 2011 | True 23 cu. ft. / 651 liter Commercial...
The compressor is running but the fans are not spinning so no cold is coming out.
Coil must be cold enough for the fan delay to turn fans on. If it is and no fans replace delay
Mar 08, 2011 | True 72 cu. ft. / 2039 liter Commercial...
The fan on my true t 23f does not run. i check it is not getting power is there a fuzz or capacitor for this thanks
Are you talking about the fan inside the freezer? If yes, check the following items. The door has a switch that turns the lights off when the door closes, it also turns the fan off when you open the door. If it isn't working right the fan won't come on. There is also a round temperature senser on the coil inside the freezer called a "clickson" that keeps the fan from coming on until the coils are below 20 degrees, it may be bad. If you are low on freon, your coils may not be getting cold enough to trip the clickson. Feel of the small copper line going from the compressor to the coils on the outside of the freezer. It should be almost hot enough to burn your skin if you have enough freon. One other thing to check is the defrost timer. It is a box about 4 inches wide and 8 inches tall with a door on the front of it. Check the connections inside to be sure you are getting power through to the fan. Let me know how it turns out.
Oct 04, 2010 | True 23 cu. ft. / 651 liter Commercial...
I have a true 2 door freezer with bun rack rails...it is runninig between 7 degrees up to 59 degrees...we vacumed the vents...do we need more coolant or what do you think...it is about 4 years old and...
Vacuuming the coil is not usually sufficient to clean them properly. Hold a flashlight behind the radiator on top of the freezer to see if you can see freely through the coils. If not, the best way to clean the coil is to spray coil cleaner on there and flush with plenty of water. It is a mess but it will get the grease off the coild. If you do not have gauges to check the pressures of the refrigerant (lets call it freon), you can get a good guess by doing the following: Get a ladder, climb up so you can see in the top of the cabinet where the compressor is located. It looks kind of like a bowling ball. There will be one small copper line and one large copper line running from the compressor. The small line is the high pressure line. It should be hot enough to burn your finger. It then goes through a small pan where it evaporates excess water, then to a "radiator" which has a fan running behind it. If the machine is running this fan should be on. The small line then runs into the freezer box. At this point the line should be warm, not hot to the touch. If this is not happening you are probably low on freon. The other copper line on the compressor is returning from the freezer box to the compressor. It should be very cold to the touch. It should have moisture collection on it. If this is not happening you are probably low on freon. Other factors can effect your freezer. Make sure the fan near the compressor is running. Make sure the fan or fans inside the freezer are running. They will stop running when you open the door, so hold the door button in when you check the inside fans. Check also to see if there is a build up of ice on the inside coil. Your freezer should run a defrost cycle 4 times a day to remove the ice. If it has ice it will not run properly. If you can remove your product for 24 hours and shut the freezer down, prop the door open and the ice will melt. On restart if the freezer goes down to 0 quickly (30 minutes) it was probably frozen over. This may indicate a bad defrost timer or heater. Try these things.
Sep 08, 2010 | True Freezer TG2F-2S
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Plugged in freezer after standing 3 days unplugged compressor ino
That sizzling noise i suspect is either the compressor overload or start capacitor burning out .
You need to look in connection box on side of compressor,the relay should just pull off once cover is off.BEWARE even with the freezer unplugged there is a charged capacitor connected inside this box and will give you a nasty shock should you touch it! with insulated pliers touch all terminals to each other and earth to make sure capacitor is discharged .You should be able to get astart capacitor and overload from local repair shop there not expensive if this doesn't fix it the compressor is possibly locked up and will need replacing
Oct 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Freezer Not Fan not running!
Most all commercial freezers have some sort of fan delay/ defrost termination device. Commonly called a "Klixon" (pronounced clicks-on). It is a device that is attached to the evap. It's function is to terminate the defrost cycle when the evap reaches a certain temp, say about 50 degrees or so, to ensure there is no build up of frost/ ice on the evap. It then allows the compressor to run, and cool the evap down to a reasonable temp., say about 20 degrees, and then let the evap fan come on. It prevents overloading the compressor during a high temp condition, and it also prevents circulating warm air left from the defrost cycle. I believe this device is most likely your problem. With no air circulating, the box will no cool down.. I have seen them burn and/or slhort internally. They can come apart. too. I would look here for that problem. the True manufacturing website does not give alot of info on this piece of equipment, such as a wiring diagram but manuals are available.
Check this out and let me know how it comes out.
May 17, 2009 | True 49 cu. ft. / 1388 liter Commercial...
True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F Logo
331 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
