Hear sound but no picture on my visio 1080p...help?
  • 38 Answers
Hello ! Most likely you are having a problem with your power supply module. You might want to call visio and have them refer you to a qualified shop. hope this helps you. Ron
Posted on Sep 09, 2009
I cannot change my Visio resolution from 720 to 1080
If it is a 1080p TV, then the TV always displays at 1080p. The source device and/or the TV will scale and frame convert the image to match the TV resolution and frame rate. When you power an HDMI device, it reads the TV's supported resolutions and audio formats over the HDMI cable, then it chooses whether or not to scale the image for the TV. The television then receives the signal and performs whatever image processing is needed to match the display needs. With many Source devices, you can use a setup menu to configure whether video should always be scaled up to 1080p. Some people prefer the image scaling of the television. However, if the Source does not upscale, it will limit the resolution of on-screen graphics, such as the program guide. So you'll probably prefer to scale your source devices to 1080p through their menus.
Mar 21, 2017 | Visio Computers & Internet
Two vizio TV's with issues
Take them to a TV repair centre as they are complex to repair. You may find that your homeowner insurance will pay for the repairs if you can demonstrate that it was a power surge that damage them.
Feb 29, 2016 | Vizio SV421XVT 42 in. LCD TV
How do I manage overpowering tv background noise
I think a surrond sound system helps. I have the same problem, i can't hear dialogue either. I can't afford surround sound system so i have to keep turning volume up & down accordingly.
Jul 31, 2014 | LG 55LV5500 55 Class 1080P 120Hz LED TV...
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
I have had my Visio 47" for 3 years. One night the screen just went blank. I could not turn it off with the remote. I manually tuned it off. then used the remote to turn it on. The Visio light and...
it sounds like you need to purchase a new video board from vizio which is expensive. upwards of 600 dollars. walmart has vizio 42 in and 47 in 1080p models around 500 dollars on sale this weekend. hope this helps let me know!
Mar 17, 2011 | Vizio 42 in. LCD TV
I have a 42" Visio
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new backlight inverter.
Hope this helps! Please rate!
Mar 08, 2011 | Vizio VW42LF 42 in. LCD HDTV
Visio 42" 1080p wont power up
Sounds like the power supply section in your tv has a bad component. Probably a bad capacitor or a surface mounted diode. One thing is for sure: something has shorted and is causing your power supply section to not fire up. Suprising to me because Visio has a good track record.
May 22, 2009 | Vizio VW42LF 42 in. LCD HDTV
Visio 32 with very little audio
If under warrenty then call vizio!
I believe its sound board but I could be wrong.
No easy fix, the part is 220$ service is 210 a used LIKE NEW 42-50 inch is 500$ shipped !
Sorry to say this but it happened to my 50 inch just before I heard a pop then it would not show a picture and had no sound.
Call them up if your tv is less then 1 yr old!
May 19, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
